Question about HP LaserJet 3055 All-In-One Printer
Firmware upgrade LJ 3055
I downloaded a firmware upgrade for my laserjet 3055 all in one printer/fax. I think I may have installed the wrong firmware and now it is non functional. The ready light no longer comes on. The formatter board is a Q7528-60002. Is there any way of getting the original firmware back into the board after it has the wrong firmware installed?
Desperate!
Rein
  • 1 more comment
  • mchris Jun 18, 2008
    Same problem, installed wrong firmware. No printer is dead. Called HP support and they said "dont ever upgrade the firmware on printers"... and told me to contact an Authorized service center.
  • Anonymous Nov 19, 2008
    Hewlet Packard is such a bunch of assholes. I also downloaded their firmware update they post on their site and it ruined my 3055. Why would they post a firmware upgrade they know will ruin your printer and then tell you never upgrade. These posts are all over the net, HP knows about it, yet they keep the firmware upgrade on their site. I am going to pay them to fix it and then I am going to sue them in small claims court for the cost they charge me to fix the computer they ruined. What are they going to say...the cost they charge to repair wasn't reasonable..ha. I will update the results of the lawsuit in a few months.
  • Anonymous Jan 26, 2009
    I upgrade the firmware, now it can only use as USB local printer. The scanner does not work.
I foud the solution read carrefuly and he will works !!!
Turn off the printer .
Open the side cover where place the formatter on the right face
Here you will se a jumper
On your computer delete all hp software
Install HP 3055 pcl 6 drivers and select manualy your usb port where is connect the printer ( the printer is always off)
Download this :
ftp://ftp.hp.com/pub/softlib/software8/COL13630/ma-38209-5/3052-55_FW_Update-20070331.exe
Open the program select your printer and send the firmware (the printer is always off)
When the firmware is upload completly and you see the smileys on the sofrware update.
Closed the jumper P19L on the formatter and turn on the printer.
You will see message on the printer Downloading.
Open immediatly the jumper connection
Wait and you will see a message like Update successfully :)
turn off the printer
wait 5 seconds
Turn on the printer
It s ok
Marc
Posted on Nov 20, 2009
  • KAKONmarc Nov 20, 2009
    If it doesn't work
    download this :
    ftp://ftp.hp.com/pub/softlib/software9/COL13615/ma-38114-4/hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe
Thanks to Marc and the previous post. While some tweaking was required for success, he brought the fundamentals needed to accomplish this fix.
MAJOR PROBLEM: HP 3055 inoperative after firmware update.
INDICATIONS: When the HP 3055 is turned on, the display window reads, "Hewlett-Packard." The "ready" light does not illuminate. The 3055 is not recognized by any computer, and does not function.
ORIGINAL PROBLEM: The HP 3055 would not scan on my computer running Vista; however, it worked fine when scanning from a computer running XP. I was updating the firmware to restore scan functionality.
HP SUPPORT: WORTHLESS!!!!
OPERATING SYSTEM: Windows Vista Business, SP2, 32-bit. This should work with an XP system as well; however, go to the main support page for the 3055, and download the appropriate updates as necessary:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140780&lang=en&cc=us&taskId=135&prodSeriesId=1161389&prodTypeId=18972
RESULTS: Following the completion of the procedure listed below, all 3055 functions work on all networked computers on all Windows platforms.
SUMMARY OF PROCEDURE: By closing the connection of the jack labeled "J19" on the 3055 formatter board, the printer will be configured to download software; thus, allowing you to reinstall the firmware, and restore functionality to your printer.
PROCEDURE:
NOTE: Read this a couple of times before actually conducting the procedure...you may not actually need to do all of the installing and uninstalling, but it's what I did, and it worked for me. If you're going to update the 3055 software as detailed at the end, you'll have to uninstall the original 3055 software prior to doing the update anyway.
1. Uninstall the HP 3055 Software.
2. Install the HP Universal PCL6 print driver on your computer. Select the LPT1 port when asked which port to use during the installation. It should be the first choice (not sure why the LPT1 port was successful). Link to Universal PCL6 driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ja-45284-12
3. Unplug the power cord to the 3055.
4. Disconnect the Ethernet or USB cable and phone line from the 3055.
5. Remove the panel on the right side (as seen facing the 3055). There is a black screw on the back near the Ethernet connection . Remove the screw. Loosen the panel at the right back, and gently apply pressure toward the front to remove the panel. The circuit board you see is the formatter board.
6. Connect the 3055 to your computer using a USB printer cable.
WARNING: I would imagine during these next steps, there is shock potential with the possibility of ELECTROCUTION! Thankfully, neither happened to me, but don't be sloppy here.
7. Locate the J19 jack (male type connector). There are two small sliver prongs protruding about midway up the formatter board next to the bottom right corner of the large square chip. The jack is labeled on the left side, "J19." You may need a magnifying glass to read the small print.
CAUTION: During the following steps, ensure that no other component of the formatter board is being touched by the jumper wire.
CAUTION: Avoid static discharge to sensitive components. Before closing the jumper connection outlined below, ground yourself by touching the back of the printer. Maintain contact with the printer with your free hand while attaching and detaching the jumper.
8. Close the connection of the J19. Closing the connection is simply the process of creating a conductive connection between the two prongs. I used a 2.5" section of insulated bell wire with about 1.5" stripped. I created a tight loop with the stripped section so it would slip snugly over the 2 prongs of the J19 jack. Any sort of conductor will work, but make sure that there is an insulated area for you to touch, so you can disconnect it safely.
9. Reattach the power cord. The jumper wire should be connected already.
NOTE: During the following update, DO NOT TURN THE PRINTER OFF until instructed to do so.
CAUTION: Avoid static discharge, ensure contact with the printer prior to touching the jumper wire.
10. Turn the printer on (just keep this hand on the printer). The 3055 display will read "Ready 2 Download." Remove the jumper cable with your free hand, careful not to touch anything on the formatter board. Now you can let go of the printer. DO NOT TURN THE PRINTER OFF.
11. Run the firmware update; ftp://ftp.hp.com/pub/softlib/software8/COL13630/ma-38209-5/3052-55_FW_Update-20070331.exe You can also access the update on the HP website. Just triple check that you are actually installing the correct firmware specifically for the HP 3055.
NOTE: As the firmware update begins, if you have more than one printer installed, you will have to choose which printer to update. A dropdown selector will appear. Select the Universal PCL6 printer that you installed in step 2. If you only have the Universal PCL6 installed it may not offer any choices, and the update may simply proceed without pausing.
12. The 3055 display window should display "Printing Document," followed by, "Erasing," then "Programming," culminating with, "Complete :)." To read full HP documentation on the update, link here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&swItem=ma-38209-5&prodNameId=1140780&swEnvOID=2093&swLang=8&taskId=135&mode=4&idx=2
13. Following successful firmware flash, turn the power to the 3055 off for a few seconds, and then restart it. It should start properly.
14. Cheer loudly :) and hoist a middle finger to HP support (more appropriately, lack-there-of).
15. Power down the printer.
16. Remove the USB cable.
17. Reattach the cover on the right side, and secure it with the screw.
18. Reattach the Ethernet cable (networked computer) or USB for direct computer attachment, and phone line.
UPDATE SOFTWARE:
1. Delete the Universal PCL6 printer.
2. Download the updated HP software.
lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
3. Install as instructed. I used a custom install, and did not install the update feature or the extended capabilities. This software is bloated enough in its skinniest version.
Hope this helps, Chris
Posted on Jan 11, 2010
How do i fix RFU LOAD ERROR
RFU is a remote firmware upgrade. Usually that error will occur when somebody messes with the printer while the firmware is downloading. Try doing the upgrade again. If it works great. But personally, I don't think that it will work. You probably have to replace the formatter. C9661-69002 for a duplex model. and C9660-69011 for the simplex(non-duplex)printer.
Mar 17, 2016 | HP Color LaserJet 5500 Printer
I have Hp Laser jet 3055 can install only the printer under windows 7, but unable to install the fax facility.Please help.
Then please navigate to www.hp.com, click on support and type the model details e.g HP Laserjet 3055 all in one printer and select your computer operating system type to download the full drive for all your printer facilities.
Thanks
May 18, 2011 | HP LaserJet 3055 All-In-One Printer
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
My printer hp lj 3005 in error code 49.2f9d please solve my problem
49.XXXX is a critical firmware error. It may be caused by a bunch of things such as bad input data or data corruption due to poor cables.
From the service manual :-
Recommended action
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
Hope this helps
Dec 29, 2010 | HP LaserJet P3005 Printer
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
MY HP LJ 3005N PRINTER GIVING 49.2F9D ERROR
Firmware upgrade. www.hp.com/go/ljp3005 firmware
Do it twice. Upgrade the firmware and then do it again. Don't ask.
Oct 13, 2010 | HP LaserJet P3005 Printer
Wrong firmware installed in HP LJ 3050
I am very sorry to have to be the bear of bad news. Usually doing a failed firmware update (or wrong firmware version) you have to return to factory or have a local computer printer shop that deals in HP printers repair this firmware mixup. There is sometimes a firmware recovery mode that can help however You would have to contact HP and ask them how to get into firmware recovery mode.
Sorry hope this helps answer your quesiton.
Steven.
Apr 22, 2010 | Office Equipment & Supplies
Our fax machine is displaying the incorrect fax number for our company on the report. How do I change it? We have a laserjet model 3055 all in one printer. Thanks Jenneka
Go to www.hp.com, select support & drivers, select "see support and troubleshould........", fill out your product and you'll find "setup, install and configure".
Gerrit Jan
Nov 04, 2009 | HP LaserJet 3055 All-In-One Printer
HOW TO SET FAX IN HP LESERJET PRINTER 3055
Pages 67 thru 117 covers all fax functions and features of your HP Laserjet 3055 in this users guide. Hope this helps.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Oct 24, 2009 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
1,958 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
