Question about Samsung RS2578BB Side by Side Refrigerator
My samsung fridge 18 months old. the freezer is working so so, however the refridgerator is not working at all any ideas.
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
May be worth a look at this
samsung fridge freezer diy video channel
some usefull diy help and info
Posted on Sep 21, 2010
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
GE side x side refridgerator temperature is
unlikely both temp.sensors will be faulty at the same time. Notice how different the internal temps.are compared to the acurate one you are measuring it against. Almost certain board is defective because incorrect info in the processor will tell the compressor/s to switch off before time.(hence not correct temp. all the time.) Suggest replacement.I normally replace probes as well to eliminate problems later..
Sep 17, 2009 | Refrigerators
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
I moved our 18 month old samsung fridge freezer Model SR281NW and one week later it has stopped working. The freezer fully defrosted and the fridge, even though it has the light on, is not cold
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
May 18, 2008 | Samsung Refrigerators
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
Samsung RS2578BB Side by Side Refrigerator Logo
223 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
