Question about Car Audio & Video
My calibra CCE 4060 Cyclopse car amp only shows the protect light when i hook it up. I even disconnected everything and just left the + ,ground and remote wire on and it still it only shows the protect light. What could be the problem
xtpfly
SOURCE: protection light on
go to power acoustiks website at: poweracoustik.com then tech support look at how to insatll an amp
Posted on Jun 29, 2007
  • 113 Answers
SOURCE: Amp will not turn off and the Remote wire is correct.
check pwm chip ,may need replacing
Posted on Aug 22, 2007
  • 631 Answers
SOURCE: car amp
The most common reason for this is shorted output transistors. To confirm that the problem is in the amplifier, disconnect all speaker wires and the RCA cables. If the amp still goes into protection, check the DC voltage across the B+ and ground terminals. It should not drop below 11 volts. Also check the remote voltage.
If the amp continues to go into protect with no external connections (other than B+, remote and ground) and the voltage remaiins above 11v, the amp is defective.
Posted on Nov 06, 2007
  • 631 Answers
SOURCE: Protection Light
This is almost always caused by shorted output transistors. To eliminate other possible problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Generally, an amp with blown output transistors can be repaired.
Posted on Dec 28, 2007
SOURCE: VB101PK REV 13, AMP WITH SUBWOOFERS
you may have to much speaker for the amp or one of ur wires could be crossed
Posted on Mar 17, 2008
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Have replaced brake light on my calibra but will
calibra??? sounds like there is a ground problem.
Oct 14, 2009 | 1999 Chevrolet Silverado 1500
My calibra amp lit the red power led (to show protection )now my subwoofer won't play
disconnect sub woofer , amp may reset and light will be steady , if so replace wireing to sub and sub its bad
Oct 06, 2009 | Car Audio & Video
Protection light
Hello. First, disconnect all of the speakers the amp is driving and the rca inputs while the amp is off. Now power on the remote. If the prot. light still stays on you will need to varify that the voltage across the ground and b+ terminals is a minimum of 12 volts. If this is true than your amp may be damaged due to shorted parts. Otherwise, try to repower the amp while a speaker is connected and if it is O.K. than there may be a problem with the RCA ground in the head unit or the amplifier. We service these amps at Sound Repair 321-690-0808.
Jul 10, 2008 | Kole audio Q1-3000D Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Protection Light
Dec 27, 2007 | Boss Riot 850 Car Audio Amplifier
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
