Question about Culligan 34" Whole House Water Filter Housing Wrench Use
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Posted on May 11, 2011
The water pressure in the entire house is very poor. If more than one water tap is open the water trickles out. The house has a Culligan Water Softner system. Is there a filter or some other home...
First make sure all the filters on all faucets (kitchen, bathrooms and even the dish washer and washer) are clean and not clogged, sometimes on areas with hard water you will experience sand and minerals to accumulate and clogged all filters. If all filter are clean with no minerals, then your problem could be the culligan filter, ask your sales rep to perform an inspection for minerals on all ending lines.
Hope this clear up your water lines. It happened to me.
Aug 09, 2011 | Culligan 34" Whole House Water Filter...
My Culligan water softner is leaking from the coonection where the tank and the control head meet how can i fix this problem?
It depends on how old it is. Older Culligan systems(pre 1999) have separate inlet and outlet on tank and have washers that fit inside the "FEET" that slide onto tank. Newer style systems have center opening tanks with o-rings that seat on tank. You need to see what model it is. Bypass the system, run through a manual regeneration to relieve pressure, then you can change the washer or o-ring. They are only available at Culligan.
RJ
Mar 24, 2011 | Culligan 34" Whole House Water Filter...
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
Silver water softner sounds like water running all the time
It is running to drain. The sealpack (main piston & sealpack are one unit) is bad and needs to be replaced. If you are handy you can do this yourself. There is a retrofit kit to help repair these issues. It is only available at Culligan. It is about $10.
RJ
May 13, 2010 | Culligan 34" Whole House Water Filter...
Will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
Water softner dirty water
you might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
May 27, 2009 | Water Heaters
MISSED RINSE on culligan softner
the unit number one needs to be reprogrammed by a professional only it is tricky and ck the motor in the unit this controls the valves turning and water direction control.
Apr 29, 2009 | Culligan Sediment Water Filter
I have a culligan water conditioner, are there filters inside unit? Im by passing the unit now. When water goes through system, water pressure drops.
yep got to replace the filters if any in line or your softners need to be relined if you cant see your filters in a plastic clear houseing then your sadly gonna have to call culligan water to come reline your tanks
Mar 28, 2009 | Plumbing
Culligan 34" Whole House Water Filter Housing Wrench Use Logo
223 people viewed this question
Top Culligan Welding Tools Experts
Bill Boyd
Are you a Culligan Welding Tool Expert? Answer questions, earn points and help others
