Compaq colour monitor 21" MODEL P1100
When i on the set it goes stand by mode EHT sarts for second goes OFF kindly guide me out
  • premtron May 13, 2008
    i tryed this yield no result
  • 975 Answers
TRY THIS, open Monitor , look inside the PC BOARD for a burn solder or cold solder around the area where you see a transformer , re solder any suspicious solder and try again, hope this helps , please rate this solution , AJ
Posted on May 06, 2008
Hello I have monitor samsung Smatron 7Ei the fault is that the picture is very dull with less contrast and bright. CRT heater volgate is ok. Secondly there is a heavy noice when i start it by power...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast --- that noise is from EHT )........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.....
Apr 18, 2011 | SAMTRON 55V 15" CRT Monitor
When i switched on monitor samsung 55v, the display comes ,with in a second display off,then power led not glowing
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....monitor just blinks & switch offs .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.... SOME TIMES ALONG WITH EHT....A TRANSISTOR ( BIG IN SIZE & FIXED NEAR EHT) ALSO GETS DEFFECTIVE...........SO IT SHOULD BE COMPULSORYLY CHECKED BEFORE REPLACING EHT...
Mar 14, 2011 | SAMTRON 55V 15" CRT Monitor
Compaq P1100 Monitor
The monitor probably is no good.
Oct 22, 2017 | HP Compaq P1100 21" CRT Monitor
Not powering on
You will need to take it in for repair. This is most likely a power supply problem.
Lou
Aug 24, 2008 | HP P1100 21" CRT Monitor
Not coming on
check your connection on your graphics.make sure you have activated your screen on control panel-display-advanced.
May 12, 2008 | HP P1100 21" CRT Monitor
Compaq colour 21ich monitor trinitronfbt
It is going into power saving mode. Can you disable power saving mode?
May 06, 2008 | Gateway FPD2275W LCD Monitor
Want Specification of EHT
I want the EHT specification
Feb 21, 2008 | Compaq MV 540 15" CRT Monitor
Picture problem
CATHODE RAY TUBES IN YEAR 2017, ?
whats it plugged into.
my guess its plugged in to some unnamed PC.
try it on , another PC yet, that monitor ,new will no recognize old monitors.
test the monitor , then if its ok then the unstated PC is at fault./
you have 2 boxes there, 1 or other is faulting.
easy no?
May 19, 2017 | HP P1100 21" CRT Monitor
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
