Question about Philips FW-R7 CD Shelf System
Panasonic SB-AK57 cable fix
Hi .. my system just dont want to start anymore .. i checked it out and the power supply smells a bit burned .. though i still want to use the speaker so i bought rca plugs so i can add them .. though the problem is that the speaker has 4 cables .. the usual black and red and a blue and grey .. i tried it with just the red and black but no sound .. i havent tried with all 4 yet becuase i dont know if itll work on other system or put a plug on the cable ... you can email me at twistedmental@hotmail.com .... tnx raj
Wont power up
Posted on Jun 22, 2008
    Genius:
  • 1,019 Answers
Hi Raj,
you,ll find that you have 2 sets of cables.
you need to use a multi-meter tester, to find a continuity circuit of the speaker. If you don,t have A Meter try the red as + and every other 1 individually as A -.
If that does,nt work try the black with any individual.
Hope this helps, solve your Problem.
Mike.
Posted on May 07, 2008
Hi everyone I have s Panasonic Sa-AK27 that is stuck on standby mode,the thing is it has been on the box for the past 5years after my dad pased on he was the owner,so now I decided to use It
Very often when left for a long time the Electrolytic Capacitors in the power supply section dry up and cause it to get stuck in standby. The only cure is to replace all the big capacitors in the power supply section.
Dec 22, 2016 | Panasonic Rak-ch944wk Sa-ak27 Sc-ak27...
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
We had a power outage - the computer was on a circuit breaker outlet. The other computer came back on, but the one with the siverstone power supply will not start up
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
May 19, 2010 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
Hi ive got an packard bell with a fsp250-60gen psu in, it started to smell of burn lately, was quite a bit of dust build up, cleaned it all out, but still smelling, isnt gettin hot, is it on its way out??...
The dust could cause the burning smell, if the smell has an electrical smell then most likely the capacitors are leaking in the power supply and about to blow/explode.
Is the power supply come from a desktop computer? If so all ATX switch mode power supplies have standard mounting holes and power connectors.
Take out the old switch mode power supply and take it with you to your friendly computer shop and compare it with a new one. Make sure the wattage rating of the new switch mode power supply is the same or greater than the old switch mode power supply.
Sep 06, 2009 | Computers & Internet
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Can i use panasonic SB-AK57 speaker (6 ohm) with yamaha system RX-V663 (8 ohm) ?
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Apr 25, 2009 | Yamaha NS-A60X Main / Stereo Speaker
Panasonic SA-AK57 alignment of CD tray and disc changer
There is a particular procedure for rebuilding these units that must be followed to insure proper alignment. This procedure is available to authorized service centers only (as far as I know). Your only alternative is to purchase the service manual that contains this procedure from Panasonic.
Dan
Apr 02, 2009 | Denon D-M50S CD Shelf System
Panasonic SA-AK57 problem
This sounds like a power disconnection problem.
you have a large amount of components, on the motherboard that charge up with being used. ( namely fets/capacitors et,c ) when your system is powering off the instant disconnection of mains power, can cause a Bang or Pop to the speakers.
I,d suggest trying swapping the speakers over from right to left and vice versa. see if the errors still there.
Also try turning the volume right the way down, before switching off. is the bang quieter ?
Check the mains cable ( plug end ) see if theres a broken or loose wire at the plu ( causing an arc ) finally check that the plug ( cable grip ) plastic tang that holds the cable, has,nt been overtightened and damaged the cable underneath it.
I hope any of this helps you to a self diagnostic rectification of the problem listed. Also try without speakers is a suggestion.
Mike @ Compurepair.
Feb 24, 2008 | Audio Players & Recorders
Philips FW-R7 CD Shelf System Logo
237 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
