Error when trying to print
Installed printer on new computer
error is reported when try to print
  • 2,326 Answers
Can you please tell me the brand and model of your printer?
What errors do you see when trying to print?
Posted on May 06, 2008
Ls-c8100dn+ will only print error report
you might check if the installed drivers are compatible with your operating system and printer
Jan 10, 2012 | Kyocera Mita Office Equipment & Supplies
PRINTER WON'T PRINT DOCUMENT ONLY SERIES OF QUESTION MARKS.
Your printer is printing "garbage print". To make sure there is nothing wrong with the printer, try printing an internal report. If the report is good then there is a problem with the printer driver, interface cable (USB, parallel, ethernet) or port.
Start by uninstalling the printer driver and then reinstalling it.
If the unit still wont print properly, try using another cable or try installing on another computer.
If the same thing happens on another computer with a new cable then the printer is at fault and needs to be reset. You should be able to find the reset procedure in your user's guide.
Thanks,
Pat
Nov 07, 2010 | Epson Office Equipment & Supplies
Trying To Print From Internet Explorer
This error only comes when the thing or program you are using is not competent with your computer. In your case, it seems that the Driver of the Printer is out-dated or seriously corrupted. Try re-installing or try to find updates on the manufacture's website.
Thank you Sir, Have a nice day.
Sep 24, 2009 | Dell 924 All-in-One InkJet Printer
I have Quicken 2009 and Windows Vista, HP Printer
I've tried off and on for a year to try to get assistance from Quicken and HP because my Quicken reports would not print. Everything else printed just fine. It was so frustrating because nothing worked. I needed to get reports to my accountant and thought I was just going to have to hand write the reports. In the end, I took a photo of the screen (with the report showing), downloaded the photo to the computer, tweeked it a bit with my photo software, then prrinted it. How goofy is this to get a report from a program that is supposed to make my life easier???!!!
Aug 19, 2009 | Computers & Internet
Printer error 15.004.45:185233
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | Xerox Phaser 8200 Laser Printer
My printer will not print.
When you get to the "Print" window, there should be the area where it says the type of printer. There is also a drop-down arrow. Click on the arrow and highlight your HP printer.
Jan 27, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
KODAK EASYSHARE 5300 ALL IN ONE ERROR REPORTS
To solve your this Issue, you need to clean install
the program, but to do that you need to call Kodak Technical
Support to guide you through the process... ^_^
Oct 24, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Does anyone know what a 102H error means on a Minolta Magicolor 2490MF please ?
The error code is a message from the computer to let you know there has been a problem reaching to an adapter or device. It indicates Port 102h register test error. It means you should try reconnecting the printer, and ensure you have the printer properly installed so that it does show up as the correct printer when you select the Start, and Printers. (Or when you go into Control Panel and then select Printers, to see the installed printers in your computer.)
If the printer is on, is completely properly connected, is properly installed and appears in the list of your installed printers, in your computer Control Panel, then possibly you have some problem with the actual whirring, paper-handling printer device. You may try shutting down your computer, after you save any unsaved work that you were doing, and close applications, and can properly completely shut off the computer by selecting Shut down, from the Start Menu. Also please disconnect any cameras and any USB hubs for this test, but keep the printer connected. No need to turn off the printer; leave the printer on. Power on the computer and recheck the status of the printer, to see if it appears in the list of your installed printers, in your computer Control Panel, and see if the printer appears to be available or ready to print. If the printer does not appear, check its connection again, move the printer USB cable to another USB connection on your PC if it was already connected, and recheck. If you still do not see your printer appear there, it seems you will need to try another USB cable or another parallel printer cable, and proceed to install the printer. See if the printer has any flashing indicator - lighted LEDs, and notice the colors, and any error message. Report any questions you have about getting the printer installed please. Report any questions or problems you have with understanding what the manual instructs you to do to resolve the reported error. Maybe the printer has just gone bad, died, become kaput.
Aug 01, 2008 | Minolta Office Equipment & Supplies
Printer won't print
Well could be multiple issues depending upon whether its installed on the network or through the USB.One thing you can try is unistalling the printer drivers from the computer in the control panel>printers and faxes and then reinstall the drivers.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jul 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
jasbo
jasbo
