Question about Lexmark Office Equipment & Supplies
How do you download the print driver software to install a printer to a different computer
  • Lexmark Master
  • 19,396 Answers
Hi.
You need to download and install driver software available on Lexmark website. Please follow instructions in the links below:
Lexmark driver se
download links printers drivers from manufacturer's website
Posted on Aug 27, 2010
49,4c18 error
49.XXXXX ERROR
A critical firmware error has occurred.
1. Turn the device off and then on.
2. Try to determine whether the error occurs intermittently, while printing, or when turning on the device.
3. If the error appears while printing, determine whether it occurs when printing from a specific computer, a specific application, or a specific file. If all other computers, applications, or files
can print without the error, then the problem may be only within one print job or computer. Make sure the computer has the most current printer drivers, or use a generic printer driver.
4. Go to www.hp.com/support/LJP3005. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the device and the device can receive a firmware update, download the newer firmware upgrade.
Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
6. If the message persists, contact your HP Support.
Feb 22, 2011 | HP LaserJet P3005n Printer
Tip
How To Use Printer
Here basic tips explaining how to use a computer printer.
Before using the printer for the first time you will need to install the driver software.
Driver software is provided with the new printer, and it is usually stored on a CD.
Insert printer CD into computer disk drive. Do not connect the printer until prompted by the setup wizard.
If you have misplaced the original disk, then you can download the printers drivers from manufacturer's website for free, click here to get a list of printer manufacturer support websites where to download manuals, drivers and software.
Once the printer is installed, if printer is new, you may need to insert the ink cartridge. In that case refer to link above to download the manual, as procedure is different depending on printer make and model.
Depending on printer model you may have to perform an alignment procedure after installing inks.
Once printer is connected you can print a test page. If you have Windows this is printable from Control Panel>Printers. Click right button of mouse on your printer icon and select Properties from drop down menu. There you will find the Print Test Page button.
To print an ordinary document, open the document with the associated program and choose print from menu bar.
For more details on printer use and maintenance, download the printer manual using the link above, or ask Fixya experts.
Good Luck.
on Sep 03, 2010 | Office Equipment & Supplies
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Prints gibberish
First test a different USB cable. A faulty data cable can cause the problem.
Once you are sure the cable is OK, reinstall printer software. A corrupted or wrong printer driver software is common cause for this kind of problem.
You can reinstall software using printer disk, or download from manufacturer website.
Start software setup with printer USB not connected.
Sep 10, 2009 | Office Equipment & Supplies
Error code 49.4c18
49.XXXXX ERROR
5. Try printing a job from a different
assistance.
HP Support.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Office Equipment & Supplies
Brother 4420c error 41
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 22, 2009 | Office Equipment & Supplies
Lexmak x1240 all in one will not communicate with computer
Hi, I am writing you regarding your problem with the printer.
If the printer is still not printing, try first replacing the usb cable, and try a different USB port.
If still no luck , then you will probably need to reinstall the driver software, either from CD , or downloading the file from Lexmark website.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Always start printer setup with printer unplugged, and chose printer as default during install.
Mar 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
Installing 942 onto inspiron 5100 - can print, can't scan
try to fully uninstall the driver, restart computer and printer. download and reinstall driver from support.dell.com drivers and downloads website.
Feb 13, 2008 | Dell 942 All-In-One InkJet Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
