Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch WFMC640SUC/03 washing machine leaks - Bosch Nexxt Premium WFMC6400UC Front Load Washer
  • drillsir Sep 29, 2010
    The problem I had was a faulty fresh water inlet solenoid. I suspect that hard water eventually caused the plastic housing to crack and leak water. This part is easily replaceable. The only tools required were a pair of pliers (to loosen hose clamps) and a torx driver to loosen the back panel screws. Search around online to find the best deal for the part once you get the part number because prices varied about 30% depending on the vendor.
4 Suggested Answers
  • 1294 Answers
SOURCE: My washing machine bosch 2401
First unplug the machine; then check all your connections and harnesses. Possible while you worked some wires could have come loose. Re. the code look in your users' manual............or surf on this site going to Bosch washing machines, from 'washing machines' above.
Please tell me somethng after you get this - yes, no or whatever...... I have quite a few solutions for which there is nothing............dont speak gama, type!
Posted on Jun 03, 2008
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Posted on Jun 05, 2008
  • 880 Answers
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Posted on Dec 01, 2009
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
Our Model WFMC640SUC front load washing machine is giving us the "suds or pump is blocked" message at the end of a cycle. We cleaned out the hoses but it still will not drain, evenn if just on...
Hook up all of the hose to your washer, get a shop vac and see if you can **** out the water with the shop vac. If you can all of the hoses are clear and your drain pump is probably defective and will need to be replaced. To verify this check to see if the drain pump is getting power in the drain cycle. You should be able to access the wiring from the back panel.
Mar 10, 2011 | Bosch Washing Machines
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
May 09, 2010 | Washing Machines
My wife washed a fuzzy blanket in our washing machine. I believe that the intake screen, if there is one, on the pump is plugged..no water can drain. How do you remove the white plug that is under the...
theres a little hole in that round cap,put a thin screwdriver and turn counter clockwise,the cap will come off and will expose the pump,also turn the pump plug also counter clockwqise and it will come off,remember get a flap pan under the pump.a bit of water will be coming out
Mar 30, 2010 | Bosch Nexxt Platinum WFMC640SUC
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
My washing machine bosch 2401 keeps displaying a fault code 03. I just replaced the drain pump? any ideas?
Jun 03, 2008 | Bosch Washing Machines
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
101 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
