Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
How do i connect 2 d-link switches - D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
    Scholar:
  • 106 Answers
I found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Posted on Aug 27, 2010
Connect a electric motion sensor switch to a standard switch
Copy following link for motion sensor and occupancy switch wiring
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 08, 2013 | Electrical Supplies
How to install intermatic PB913N66
Open following link to identify timer:
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
The timer has 4 terminal connections.
2 terminal connections are for the clock motor, and 2 terminals are switched just like ordinary light switch.
See how to connect terminal ends to electrical wire by crimping:
http://waterheatertimer.org/Terminals.html
Which 2 terminals are for clock, and which 2 are for switch?
Test across both sets of terminals using continuity tester or multimeter set to read ohms.
Then rotate override knob to next position, and repeat test on both sets of terminals.
The set of terminals that changed when override was rotated are the switch terminals.
The other set of terminals are the clock terminals.
Connect 120Volt Hot and neutral to the clock terminals. Turn on power and make sure clock dial rotates.
Next: the cable going to Load has 2 wires: Black and white.
Cut the black wire. Crimp terminal connections on each end. Connect each end of black wire to the switch terminals.
To set timer for on-off operation, open following link:
http://waterheatertimer.org/How-to-set-timers.html
Sep 25, 2011 | Hardware & Accessories
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
How to connect my d-link 2 my pc's (laptop and desktop) for data transfer
power on switch , have two patch cord with you, first connect in pc's eathernet port and second in laptops eathernet port,connect those cables to switch's lan port respectively start the switch and turn on pc and laptop and main thing enable sharing in remote desktop.
Mar 02, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Aug 31, 2010 | D-Link DSL-G604T Wireless Router
I have a d-link kvm-121 connected with 2 pc desktop when both pc is on 1 of the pc will see the shadow of another pc and then i tried to plug off the vga cable of one of the pc there are no more shadow....
The D-Link 2-port PS/2 KVM Switch with Audio Support(KVM-121) allows you to .... docking station and a Dell desktop, using a logitech PS/2 mouse and keyboard. ... as it easily allows me to connect another computer when I'm troubleshooting problems. ... See the nine (9) Hot Keys on page 9 of the superbly written and ...
www.amazon.com › ... › Cables & InterconnectsKVM Switches - Cached - Similar
Jun 30, 2010 | D-Link KVM-121 2-port KVM Switch
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Hello Dear, I have 2 D-Link 10/100 Fast Ethernet Switches and 1 Broadband Connection (which requires Username & Password) and want to simple networking in my office lab i.e. pc to pc networking not...
my dear, you a router in order for you to connect or use your simple network . . you don't crossover cable in that particular situation . . here's the connection . .
1. from WAN to router - you already have that i know
2. from router to switch - use straighthrough cable
3. from switch to pc's - again straight cables . .
i hope this will help . .
Jan 14, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
393 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
