Question about GE GBS22HCR Bottom Freezer Refrigerator
The freezer works, but the refrigerator part doesn't. The light in the fridge works properly. If I turn the dial down to zero for the fridge, then the fan shuts off, and if I turn the dial back to 5 or so then the fan kicks back on, but no cold air is coming out. I've tried to unplug it for a minute to see if that would reset it, but it doesn't seem to work. What is the problem? Is there anything I can do to get it working again.
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
Freezer works but fridge doesn't for Doc Henn. I couldn't see your video but more common reason for this would be the small fan usualy behind the inside back panel of the fridge. The freezer is the pa
Check to make sure the light in the fridge shuts off when the door is closed. You'd be surprised how much heat is given off by that light. If it stays on either take it out or replace the switch.
Apr 02, 2013 | Refrigerators
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator section works, freezer not working properly
fridge is cooling but freezer is not temp control is turned all the way up?
Jul 10, 2008 | Refrigerators
GE GBS22HCR Bottom Freezer Refrigerator Logo
262 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
