Question about GE JVM1440 Microwave Oven
Just stopped working! No power. Have already checked via other electric outlets.
  • 15,935 Answers
Fuse has likely failed. Hoever the power supply must be tested.
The repair is going to be almost as much as a new unit with warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 27, 2010
Fan stays on, microwave does work, how can I get the fan to stop running?
Hello, Wanda -
Until you can have your microwave repaired, if that is what you ultimately wish to do, you can pull out the plug from the electrical outlet for the power cord for the microwave.
With no electric power, the fan will stop.
Jan 10, 2018 | Microwave Ovens
My microwave does not have any power. The electric outlet works, so I am wondering if there is a reset button somewhere. Model number: WP1000AP30-3. Serial number is FMD0210400437. Thank you.
If you have checked plug fuse there is an internal fuse but you have to remove cover to find it.if you do remove cover "MAKE SURE THAT IT IS UNPLUGGED" AS IT CAN KILL YOU"??????????????
Oct 21, 2017 | In Microwave Ovens
I have a 2000 23ft comfort travel trailer, it is pluged into electrical, all lights work, but I do not get any power from outlet plugs. I checked breakers & fuses, no outlets work.
On my trailer the gfci is a seperate button in the fuse panel that shuts down the 120v outlets, all the lights run off the 12v so they continue to work, does your microwave and ac work?
Mar 02, 2015 | Microwave Ovens
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
Sep 09, 2009 | Kenmore Microwave Ovens
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
GE JVM1440 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
