Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Surround sound connected a bose 321 surround system and the sound cut off on the tv
  • Anonymous Mar 23, 2014
    cant get tv to connect to bose sound system
No resolution
Posted on Jun 04, 2008
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Apr 28, 2011 | Bose 3·2·1 II System
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
I'd like to add two speakers to my older 4 pin Bose 321 system. Can I buy adaptors to split off the two small front speakers to run two additional speakers to the rear of the room?
is there any connection for 2 more speakers?
if not there is no real way to make it surround sound . however you can double up the speakers with the front ones.
but you loose sound quality and it wont be true surround sound. but you can give it a try
Apr 21, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose 321 lost sound
Check wiring from DVR to TV and surround system...TV may now be getting audio signal from DVR via HDMI/DVI cable. If so, the Bose needs to be connected to either optical/audio out on DVR, or on the TV's audio out jacks. If there is only one cable from DVR to TV, that is probably the case. This is just a general solution, if it doesn't help, reply with make & model #'s of all devices involved, I might be able to help more.
Mar 16, 2008 | Bose 3 2 1 GSX System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
