Question about Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart
I have an older model and the model number is worn out. I need the instructions and service manual for it. It does not seem to be suctioning and I already know the suction assembly is missing but do not know which one to purchase or if they are universal. Only numbers I can read are as follows: Campbell Hausfeld Paint Pro Contractor Airless Paint Sprayer 115 volt 7.8 amps 60 hertz 101395 or 101305 (not sure which) N062427 DK615204AJ AL230502LE and model number I could only read the last two digits 08
5 Suggested Answers
ivan6227
  • 35 Answers
SOURCE: campbell hausfeld paint sprayer has no suction
The same thing happened to me before if the paint is too thick. Another reason was when the gun toppled over and paint went into the spring and needle in which case you will have to take it apart and clean it.
Posted on Nov 01, 2008
  • 256 Answers
SOURCE: DECLOGGING DRIED PAINT VEINS IN MANIFOLD
You can't hurt it any more than it is, so I would try a liquid paint remover/stripper and let the metal parts soak over night. I'd be more careful with the plastic parts. Poke in the holes with a fine wire (paper clip) or pin. About the service manual, use a search engine (Dogpile, google) and search the web.
Posted on Jun 01, 2009
  • 98 Answers
SOURCE: Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Posted on Feb 21, 2010
shaymm
SOURCE: owners manual for a campbell hausfeld model # AL233300LX airless sprayer
http://www.chpower.com/manualsearch/
Manuals for Model: AL2333Manual Description Classic Mega Bytes
AL SeriesParts List- AL Airless Breakdown.6AL SeriesParts List- AL Airless Models - Breakdown with Block- 2001.073.1AL SeriesSafety Sheet- 2011.06AL SeriesSpecifications- Airless Tip Compatibility.3AL SeriesSpecifications- Paint Tip Selection Chart- 2003.04.5
Posted on Oct 16, 2012
Replace oil suction line
Oil auction line on what? Please be more specific add brand, model number, and possibly serial number
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Aug 07, 2016 | Stihl Garden
My 88 year old mother bought a Dirt Devel DHC001 - has been used twice but it looks blocked and has no suction but there is suction at the pipe end if I take it off. I have opened the red end and emptied...
to answer this properly, I am going to need the actual model number on the bottom of the unit on the silver/metallic sticker. Usually MO###### If you can get that I can help you out further.
Mark
Nov 06, 2010 | Vacuums
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Apr 30, 2009 | Sunbeam 3852 Waffle Maker
Need installation instructions for an older model microwave
It's not available for free download but you can order the installation manual for $7.19 here.
It's part number AP4252172.
Feb 28, 2009 | Microwave Ovens
GDO repair
If unit is pre 1993 (Safety beam era), Sears will not sell you any parts. Google Liftmaster gear kit. Buy for $25-30. Not hard if you are handy. Buy the complete kit with bearings.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Siemens/Bosch Vacuum cleaner
I ordered both a motor and belt by calling the Bosch service number in the manual and installed them myself, but quickly they failed again, the nylon cogs burned off (wish I could just get the cog wheel, but they have to sell you the whole motor). I bought a second Vax branded machine, which worked okay at first but now it constantly needs to be emptied for suction. Now I'm hoping to swap the bottom of my new machine with the top of my Bosch which doesn't have the suction problem. Good luck. Susan
Nov 09, 2008 | Vacuums
Venting
I would suggest that you check the manual to be sure it;s set up right.
Then you need to check any filters that are in place.
You should also check behind the grille for any obstructions or dust, etc.
1. Unplug it from the outlet.
2. Remove any screws and unlatch any tabs in the vent grille.
3. Pull up and/or out to remove the grille.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Sep 28, 2008 | Whirlpool MH7155XM Microwave Oven
Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart Logo
260 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
