Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose lifestyle model 5 /Acoustimass 25 sub power problem
I have no apparent power to the receiver, have checked the transformer, it is good, previous post suggest it is a capacitor problem or a fuse....if it is a fuse is it in the sub and how do I get in there? I got inside the receiver and there is no "apparent" damage.....need advice js
  • 2 more comments
  • Anonymous Jan 26, 2009
    I have no power to the sub and i am also wondering what I can do to fix this.
  • quickfixx Feb 26, 2009
    No power to the main unit.
  • loveindy Mar 20, 2009
    No display, no lites at all. disc wont spin. Transformer output about 14 vac, normal and in accordance with the rated output. There must be a fuse on the circuit board, but I dont see it. Just resistors, transistors, diodes, etc. No clip in fuses, no soldered in fuses. But there must be a fuse, because thats the way engineers design systems to prevent fires. Where's the darn fuse?
    loveindy@cox.net
  • quality-1st May 19, 2009
    no power to the main module and no volume control on the receiver/head unit. any ideas on self repair to avoid sending it back for a hefty repair bill to bose?
Open or leaking components will look OK but, may not function as designed. Rather than create more problems, please consider whether the unit is worth repairing by a pro/tech, if so, do so.
Posted on May 10, 2008
Have you try plugging in the power cord.. Switch off the power cord.
Posted on Jun 04, 2009
Where can i find a replacement audio input cable for acoustimass powered speaker system model 2683 5 pin din
See on ebay.com for used or new one of it as other trading sites sell quantities. Such as alibaba or aliexpress for chinese or amazon for better qualities
Feb 27, 2015 | Bose Lifestyle Acoustimass Powered Speaker...
Bose acoustimass series 5 subwoofer doesn't work
I guess it is powered.If so,check the fuse,then transformer.If these are Ok,then there's probably a fault in the power circuit.
Sep 29, 2012 | Bose Stereo Subwoofer Speaker Acoustimass...
Can't power up my BOSE 1995 Lifestyle Model 5 Music Center
you might want to google the service manual for the system as i did. this will show you how to take it apart. after doing so check the solder points along the dc power jack( power adapter plug on the unit). i was having the same issue and carefully inspected all the components... i resoldered the dc power jack and viola! powers up. btw, my system is bose acoustimass 5 music center model 5 (1995). good luck!
Aug 07, 2012 | Bose LifeStyle 5 Series-III CD Shelf...
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Oct 25, 2009 | Bose Lifestyle 25 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Bose Acoustimass 15 System no power
same problem, i found the transformer looks like the wax or glue melted down on the cir board . . . not sure if that the problem but has anybody seeing the same ?
Sep 20, 2008 | Bose Acoustimass 15 System
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Bose Acoustimass power
the amp is overheating. Disconnect one speaker at a time to see if problem persists. If so, the amp needs serviced.
Nov 08, 2007 | Onkyo TX-DS575 Receiver
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
Bose LifeStyle 5 Series-III CD Shelf System Logo
1,390 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
