Question about JVC PC-XC60 Shelf System
I just purchased the JVC PC-XC60 10 disc changer at a yard sale.....works great..I am looking for a user manual...any help??
4 Suggested Answers
  • 8 Answers
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Posted on Mar 01, 2010
  • 5370 Answers
SOURCE: Cannot open or eject CD's
Turn the unit off.Then take one small thin strong knife or knife like object.Then insert it in the side of the tray.Then wiggle the knife a bit and turn the unit on and then press the eject button few times simultaneously and also wiggle the knife a bit.Take care you dont scratch any part internally while wiggling the knife.If the tray is getting stuck ,then this releases the tray out and it ejects the cd.-------------- But if this is not helping then the jvc unit has to be disassembled and internal tray assembly parts has to be inspected manually for any blocking/crack or damage.Its fitted by screws.But take care.You mark the position of the screws before removing it and before moving any internal parts mark/note down its position,so while refitting the parts you dont face any problem.The eject tray comes out and goes in via gears and this gears get movement via motor.So you will have to check this gears,motor and eject tray position.Either of this is misaligned and causing the problem.If gears or motor checked out faulty,then you will have to get the parts,you can get this from local electronic tv/vcd/dvd repair center or from online parts stores like www.radioshack.com .---------- This should help.Thanks.Helpmech.
Posted on Jan 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: why does my jvc pc-xc60 shut off after 5-10
Possibly heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Feb 21, 2011
Have no recovey disc/ how to burn one
Why ? go to windows recoverypartition.push F8,F10 OR DEL. there is tools for recovery.
Oct 28, 2012 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Sep 27, 2011 | JVC AM FM CD DET FACE CAR STEREO
Have a 12 disc player, played great, added cd's and get code 1E3
I presume you have a fault in your mechanism that is giving the wrong signals to the processor to hang up. Reset the changer if there is a preset present. Further you will need to remove the CD's from the changer and check if any of them are warped or damaged.Do repeat to load one cd and test, if this works then you are encoundering the fault when the changer loads, changing the trays. Look into the tray section for any change in the alignment.Clean off any dirt on the mechanism,look out for any broken flexible cords that moves for the motor drive. Also look out for any motor jamming of the load motor and the drive motor. You will need to look carefully for such faults to remove this error.
I hope this helps. Good day
Jul 07, 2010 | JVC CH-X450 12-Disc CD Changer
Need instruction manual for a JVC Model KD-MK88 12-Disc Changer
The user manual for your device is available for free download at DDService.net. You can download the manual directly by following this link: CLICK HERE
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Kind regards,
BearWeb
Mar 13, 2010 | JVC Car Audio & Video
I have a jvc 12 disc changer for my car ch-x11 and I would like to know what radio station i need to set it on for it to work?
The CH-X11 needs to be paired with a JVC CD controller. See the downloadable manual at
http://books.jvc.com/booklist.asp?Model=ch-x11
This unit does not broadcast at the lower FM band.
Mar 02, 2010 | JVC CH-X1100 12-Disc CD Changer
I need an instruction manual for a Robospaiens V1
The instruction manual can be found here:
http://www.therobosapien.com/users-robosapien-manual.htm
You can either view it online or download it as a PDF file.
Nov 14, 2009 | Wowwee Femisapien Robot
Model KS RF-150 not working!
can u sell me the cd changer part where the cds go?
Oct 16, 2007 | JVC 12 DISC RF CHANGER MP3
JVC PC-XC60 Shelf System Logo
185 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
