Question about Frigidaire Microwave Ovens
How do you set minutes on microwave for more than six minutes?
Read the owner's manual
Posted on May 07, 2008
My maytag cmv1000ada starts and seems to be working, but barely warms food, it makes a little buzzy/ vibrating noise at startup but doesnt heat food like it used to example a bag of popcorn would be burnt...
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 31, 2013 | Sanyo Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Oven will only run for a minute twenty six, then it shuts down, and comes back up twenty minutes later
your thermal cutout on the side of the magnetron is defective,sounds like the mag is getting very hot,and taking a long time to cool so thermal can reset
Sep 07, 2009 | Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
Oct 26, 2008 | Microwave Ovens
900w Emerson Microwave Oven
I just came on the internet to search the microwave, and mine is the 900W red version and i have only had it-well less than a year, and it just stopped. No noises, just stopped while i was defrosting some chicken. What the heck. Not cool.
Dec 17, 2007 | Emerson Black Microwave Oven
Emerson Microwave MW8102ss
check control panel, may be problem at control circuit.
Aug 13, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
