Question about Posiflex Jiva 5800 All-In-One (tp5815r2w2k) Network Terminal
Back light - Posiflex Jiva 5800 All-In-One (tp5815r2w2k) Network Terminal
  • 82 Answers
If you are saying that your screen is dark/blank. Then yes the back light or the inverter is the likely culprit
Posted on Aug 27, 2010
When I turn on the power the screen will light up briefly then go off, then the standby light goes on (red) and flashes in four times flash intervals
4 blinks notifies the back light failure . could be the back light inverter board or faulty capacitor on power supply board.have added the image of back light inverter. Also added the picture of the power board. On the picture the capacitors marked with red should be replaced first. If shows the same complaint even after that then you have to change the back light inverter board.
Power supply
Back light inverter board
25849195-rpi3jfilu1hke134nfog5c4e-2-9.jpg www.electro-medical.blogspot.com
Sep 04, 2015 | Sony KDL46V2500 46 in. HDTV LCD Television
Light issues
I would check the ground connection on the back which could affect the lights not working
Apr 20, 2015 | Cars & Trucks
Solution for samsung monitor no screen light in display
bad either inverter board for screen back light or busted back light.you will need to remove back cover to access the inverter board and back light inside.the back light is covered with plastic and metal shield located at the top and lower portion of the screen panel display.
Sep 07, 2012 | Samsung Computers & Internet
The head lights are on but the back lights don't
Open the boot, then remove the cover of the back light then replace the bulb.
Sep 25, 2011 | 1989 Toyota Camry
No back light in display
The back light bulb is dead. Or check your phone settings, look out for display settings, select back light time/settings and see if the back light is turned off. And if not, the the back light bulb is dead for real.
Take care
Nov 19, 2009 | Nokia 1600 Cellular Phone
What is the tiny black button on the back of my black berry storm for? Its behind the back cover.
New Power / Lock button usage
Using the Power or Lock button on the top of the BlackBerry smartphone, you can perform the following tasks depending on the state of the BlackBerry smartphone:
State of the BlackBerry smartphone: Unlocked and the back light is turned on
Action: Press and release button.
Result: Locks the BlackBerry smartphone and turns off the back light.
Action: Press and hold button.
Result: Turns off the BlackBerry smartphone.
State of the BlackBerry smartphone: Unlocked and the back light is turned off
Result: Turns on the back light.
Result: Turns on the back light and displays the power off prompt.
State of the BlackBerry smartphone: Locked and the back light is turned off
Result: Turns on the back light and displays the unlock prompt.
Result: Turns on the back light and presents the power off prompt.
State of the BlackBerry smartphone: Locked and back light is turned on
Result: Presents the unlock prompt.
Action: Press and hold.
Result: Presents the power off prompt.
Oct 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Dark tft monitor
Hello atahirkhelii,
This is an indication that your back-light or inverter has malfunctioned. This problem is tricky, because if the back-light is a separate unit you will be able to repair this problem by replacing the back-light or one of its associative components, however if the back-light is part of the screen so as to make it one unit, then the repair job becomes cost prohibitive.
The troubleshooting process is as follows:
1) take the cover off of the screen panel and expose the back of the screen and the circuitry of the main board.
2) with a multimeter measure the test point voltages as compared to the schematic and note any abnormalities.
3) using the schematic as a guide determine if the back-light can be turned on manually (this is just a test to see if the back-light or its circuitry is the problem)
4) if the back-light circuitry is faulty replace the malfunctioning components,if the back-light is faulty replace the back-light (if possible, because the back-light may be part of the screen)
5) If you can replace the back-light order it from the manufacture to insure compatibility.
6) if you can not replace the back-light because it is part of the screen, contact the manufacture and ask them the cost of a new screen/back-light combination.
7) replace the components, close the unit back up and then do a 48hour burn it test on the player.
I hope this helps,
Thank you,
Shuttle83
Oct 08, 2008 | Mintek MDP-1810 Portable DVD Player
Troubleshooting 1984 chrysler back brake lights
There is a contact (not short) between wire to brake light and to back light on passenger side, when you press the pedal, electricity is absorbed by barake light bulb and back light dim out. Check cables and connectors, if necessary follow back cables to battery.
If the contact is a short the back lights fuse will blow, I think it is a contact between same polarity cables, not a short.
Regards
May 16, 2008 | 1984 Chrysler Fifth Avenue
Posiflex Jiva 5800 All-In-One (tp5815r2w2k) Network Terminal Logo
Top Posiflex Computers & Internet Experts
Will Halftowaite
Andre Fourie
Level 1 Expert
Are you a Posiflex Computer and Internet Expert? Answer questions, earn points and help others
