Question about Braun Syncro 7526 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
  • Braun Master
  • 1,610 Answers
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a rel='nofollow' href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a rel='nofollow' href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Posted on Aug 27, 2010
Where can I purchase the circuit board and batteries in Johannesburg
Braun no longer supplies this type of replacement part for any of their shavers. Unfortunately, they are no longer available.
Mar 26, 2014 | Braun Syncro 7526 Electric Shaver
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
Braun 7526 not pumping solution
The pump is no longer working. You will need to replace the unit. Replacement can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 10, 2013 | Health & Beauty
It will not hold a charge from the stand but will from the cord directly. it also does not clean properly model syncro 7526
The stands for these Syncro models are notorious for breaking. If your shaver charges direcly fom the cord but not the base, it sounds like there is an electrical problem with the base...probably the circuit board is bad. Parts that you would need to fix it are no longer availale from Braun. You will need to replace the unit. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Aug 28, 2011 | Braun Syncro 7526 Electric Shaver
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
My 7526 won't clean cycle
It is probably plugged up at the base. Take the cartridge out and turn it upside down> next clean the openings with a cotton swab< it make take a while as it can get gummy> That should fix the problem
Oct 30, 2009 | Braun Syncro 7526 Electric Shaver
The razor head comes loose from the two arms.
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Mar 11, 2009 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
356 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
