Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My daughter's GE Profile performance TPS24PPBGRS side by side is accumulating ice at the bottom of the freezer. Can you help us with this problem? Everything else seems fine. Thank you
I had the same problem. Check the hose that feeds water to the freezer. Mine had cracked and was leaking to the bottom and freezing. good luck
Posted on Sep 04, 2010
  • lyleogle Nov 05, 2010
    Where was the water line located? Mine is doing the same
    Mine is doing the same. Where is the run in the refrigerator?
Water accumulating and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
Apr 14, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
There is always water accumulating under the freezer door on our side by side, we tried defrosting it but didnt help
SOUNDS LIKE YOU HAVE A CLOGGED DRAIN ON UR FREEZER,SIDE THE WATER COMES FROM WHEN THE FRIDGE GOES INTO DEFROST MODE, SNCE THE DRAIN IS CLOGGED THE WATER FINDS IS WAY SOMEHOW, RUNNING TO THEBOTTOM OF IT FREEZER ICING UP FOOD OR METAL RACKS,
GO ON THE FREEZER SIDE AND ON THE BACK PANEL REMOVE THE PANEL SCREWS AN YOU WILL SEE THE COIL LOOKS LKE A ALUMINUM GRILL.......KIND OF.....AN AT THE BOTTOM OF THE PANEL YOU WILL SEE A ALUMINM PLATE ON IT THERE WILL BE ICE, TAKE A BLOW DRYER AN MELT IT ALL, ONCE U MELT IT MAKE SURE THE DRAIN HOLE IS CLEAR,A CHEAP WAY AN EFFECTIVE IS TO TAKE A PIECE OF COPPER WIRE WRAPPED AROUND THE HEATHER ON THE COIL AN RUN ABOUT 2-3 INCHES INTO THE DRAIN....HEAT TRAVELS TRU COPPER WON'T BURN IT WILL JUST NOT LET THE WATER BECOME ICE AN CLOGGED AGAIN, I DONE IT MAY TIMES AN HAD NO MORE PROBLEMS ON DIFFERENT UNITS. GOOD LUCK! LEAVE SOME FEEDBACK.
May 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
TOO MUCH ICE
just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Dec 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the drain pipe located in the side by side profile ge
in the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Refrigerators Logo
477 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
