Question about Marantz SR6004 71 Channels Receiver
Hi There, I am awaiting an Marantz SR6004 (and dreading the POD issue, which I hope will pass me by). To that end, though, I want to connect a turntable. There is no phono stage, but I am wondering if I can use any of the other analog audio "in" inputs, or if I must buy a preamp. and if I do buy a preamp, what inputs should I sue on the AVR? Thank You.
3 Suggested Answers
markfreedman
  • 312 Answers
SOURCE: AVR SR6004 switches off while
There are two circumstances that I know of that a properly installed unit such as your Marantz would shut down. So here is the Theory and Data I know of.
A Your receiver has a great deal of amplification power. If it is in a closed cabinet without excellent ventilation, it will shut down if used at high volumes because because over heating. Because of it's very high power, when played loudly, it generates excessive heat.
When watching certain movies the BD player may be over-driving the limits of the amplifier section of your receiver. Page 78 of your owner's manual addresses this. Here is a link to download the manual from Marantz.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
B There is one other very important thing I should mention to you. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What tends to happen is that the listener and often the engineer running the sound mixing board at a concert(after a certain period of time) believes the sound is not loud enough when it really IS loud enough. (this tricks the audience as well) and engineer turns it up. After turning it up, his mind (and the audiences') turns it down mentally and they again think and agree that it not loud enough and then again, the volume level is turned up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours at 110 decibels. permenant hearing loss is exactly just that. Permenant! It just doesn't come back. If you use this information, you will enjoy hearing music for the rest of your life.
I hope this helps,
Best Regards,
Mark
Posted on Jan 22, 2011
  • 6771 Answers
SOURCE: how do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Posted on Apr 15, 2012
SR4600 standby light on, what is the steps to reset. Red light not flashing but stays solid when powered on
On the SR6004 the factory reset is accomplished by holding the Surround Mode + Clear buttons for 3 seconds. You may need to check the last page of the troubleshooting section in your manual if your model is different.
Dec 30, 2015 | Marantz Audio Players & Recorders
On the marantz av7702 it tried to upgrade and said connection fail 01.And now I can't get it to show on the tv.this marantz is starting to ---me off
Reset to factory and make sure you have a good network wifi signal before starting a firmware upgrade. The reset is listed on the last page of the troubleshooting section of the manual. (Surround + Clear for 3 Seconds on my SR6004)
Dec 29, 2015 | Marantz Audio Players & Recorders
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
Music from Android through my Marantz SR6004 without RX101
Buy a headphone 3.5 mm jack to RCA converter and plug it into aux jack
Nov 30, 2013 | Marantz Audio Players & Recorders
Marantz Problems
It almost sound like your player is on a standby mode or something if you turn it on and it turns off. You turn it back on and it stays on is because when you think you turning it on, it was actually turning it off. Sound kooky but that's what it looks like to me.
Nov 23, 2013 | Televison & Video
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
Hello, I am wondering if I really need a preamp to connect a turntable, or if I can use any of the SR6004's analog inputs? Also, if I do need a preamp, which inputs on the AVR should I use? Two reviews...
Having looked at the manual it makes no mention of connecting a record player. So I think we can assume that there is no built in pre-amp for a magnetic cartridge. So you will need a pre-amp for that. You can use any RCA sockets on the device that are Left and Right audio in. A tape or CD player one will do the job, as long as they are analogue inputs.
Dec 03, 2017 | Marantz SR6004 71 Channels Receiver
My sr6004 cannot on.power led is blinking fast.
to turn on , press and hold down surround mode,exit and clear buttons for more then 3 seconds,system should reset. if it goes back to a flashing power light you will have shorted output transistors inside your receiver.
Mar 31, 2010 | Audio Players & Recorders
Anyway to use Bose companion 3 system without the control pod?
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Read more: Can i operate my bose companion 3 without the control pod? - I lost my control pod. can i go around it. :: Ask Me Fast at http://www.askmefast.com/Can_i_operate_my_bose_companion_3_without_the_control_pod-qna6342714.html#q3658086
Jun 29, 2009 | Bose Companion 3 Computer Speakers
Marantz SR6004 71 Channels Receiver Logo
159 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
