Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5570Z w/ 100 percent fully charged battery it takes too much time before it turns "on" after many attempts in pressing the "on" button switch.
  • 244 Answers
SOURCE: drivers xp for acer aspire 5570z
you can download it from www.acerpanam.com.
Find the driver under these models
Aspire 5570z = Aspire 5570 = Aspire 3680 = Aspire 5580
Posted on Apr 12, 2008
SOURCE: drivers for acer aspire 5570z
i need all drivers for acer aspire 5570z driver for win xp
Posted on Sep 15, 2008
benwabnick
  • 2404 Answers
SOURCE: My Acer Aspire 5570Z laptop's power button issue
Underneath the power button that you see is a small board with a tiny tactile button. These tactile buttons because they get used alot tend to go bad. They will get worn out and then eventually won't work.
Best thing to do is to go to this page courtesy of Acer:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
There is a phone number there and they should be able to tell you if your laptop is under warranty. If its not, ask them the name of the board underneath the power button and its part number and you can search for it yourself on the internet to get the best price
Posted on Jun 25, 2009
benwabnick
  • 2404 Answers
SOURCE: Acer aspire 5570z white screen
its either going to be a problem with the lcd, inverter or output from the motherboard probably.
Best thing to do is to try a different lcd with a different lcd cable, then if that doesn't work, then try to get a different inverter, if that doesn't work then you'll know for sure its the output coming from the motherboard.
Alot of times the LCD's go bad but the lcd cables go bad cause they are flimsy and the wires break inside.
Look on Ebay cause you can easily get these parts cheaper then most places.
Posted on Aug 09, 2009
leethedeuce
  • 4472 Answers
SOURCE: acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
Posted on Aug 11, 2009
Acer Aspire One Notebook model A0532H battery wont fully charge
Fully charge battery and if not 100 percent replace.
Nov 23, 2012 | Acer Aspire One PC Notebook
I have an acer aspire one .The problem is that it's battery dfoesn't get charged over 75% even after prolonged charging.
This shows that the battery is not healthy enough to accept 100% charge and is only healthy enough to accept 75%.
The solution is to claim warranty support on the basis of a faulty battery, if you have not had it long.
The alternative option is to purchase a replacement battery, you may even get one that holds more charge. A 6cell will enable you to use your laptop longer than that of a 3cell.
Thanking you
damnor01
Apr 11, 2011 | Acer Aspire One D250 (99802378332) Netbook
Acer aspire 6920 battery problem.. laptop only recognizes the battery and will not charge now... and only lasts a few minutes
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
1.first Instal the E-power management to your machine.(Didn't had means kindly download the application from our website www.acer.co.in.
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 16, 2010 | Acer Aspire 6920 Notebook PC
Aspire One Netbook 8.9" Notebook : I have an Acer Aspire One D250 great little comput...
If you are looking for Drivers then I would recommend an Automatic Driver Download Tool that can detect all your installed hardware, search, download and install all the required latest model and manufacturer specific drivers automatically.
Regarding the Battery, some intelligent batteries remember the charge. If the first time you do not let it discharge completely, then it remembers that setting and never charges more than that. So just try discharging your batteries to zero percent and try recharging it. I am sure it will charge to 100% this time. Read more at www.fixpcfreeze.com
May 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have got acer aspire 5520 the problam is when i charge my laptop it says the battery is full so i unplug charger then it stays on 99 percent then after about 20 mins it will go off and when i switch back...
it sounds like your laptop's battery has a reduced charge cycle. I recomend charging it to full then letting it die 3 -5 times. (to completely die means that it wont turn on at all. usually this takes a couple of times turning on to be sure.) this should reset the internal memory there by restoring its charge capacity.
Jan 04, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire battery
first, you must release your harddisc drive. and see what is happen for next minutes, after you insert that batteray and plug in your adaptor, to your laptop. See indicator lamp, blinking = still charging into baterai. Light ON = full charging. And charging process, see your laptop, what did you press any button for charging batteray?
If you still press any button, clean all hardware inside of bottom case and upper case.
Sometimes dirty can disturb that process.
Sep 07, 2009 | Acer Aspire 5100-5022 Notebook
Acer 5570Z wont power on
http://support.acer.com/ you should find all the answers to your Question at there support site
Aug 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
The power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
Jul 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer 5570Z......... Battery Reported as UNKNOWN!!!
To break in a battery for Acer, you have to charge it up, then let it run down completely 3 times! The battery only has a 300 recharge life, so you must never leave it in your Acer when you are plugged in. Use it only when you need a battery, then take it out. Be sure to use it set for battery use, with minimum drain. only recharge it after it is exhausted. It sounds to me as if you bought a bum battery.. Call them, and ask for a replacement.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
