Hi, I have a 8G memorex flash drive with a lot of information on it. When I input the flashdrive into my computer the computer does not read it at all. I have taken the flashdrive to a computer IT guy which wanted to put it through a recovery system to recover the data but he says that he can't even put it through the recovery program because the computer does not read it and that his surspition is that it is a harddrive problem and not a software problem. Can you perhaps please assist me and tell me if there is any possiblelaty of recovering the data on the flash drive. Thank you very much.
    President:
  • 2,666 Answers
If an IT professional has already tried I would doubt if you will be able to recover any of the info.
This isa good example of the need to have a backup of any drive.
Posted on Aug 27, 2010
My 16 GB flashdrive says no media
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 03, 2012 | Memorex Mini TravelDrive - USB flash drive...
HRDP Password
HRDP password reset instructions Compatible Flash drives: SanDisk Cruzer Talent Flash Corsair Voyager Lexar Traveler Kingston Formatted to FAT32 (flashdrive) Plug in flashdrive to pc.. Select my computer. Right Click on flash drive from my computer select format. select FAT32 Copy and paste file to URL www.fusiondvrsupport.com/files/embedded/HRDP_dvr_install_2.5.7.50-3.0.0.60.zip DL File to desk top. Unzip file and copy and paste files only to the flashdrive. Do not move folder only files. Shut down HRDP. Plug in flashdrive. Power up HRDP. Update will perform which will default password.
Feb 18, 2012 | Honeywell HRDP4F250 250GB 4Channel DVR 4...
I deleted all the memory in the flash drive, its a 2 gb, but it tells me that theres only 41mgb in it.
Try emptying you trash on the computer that you deleted the information on. Or recycling bin depending on the type of computer. When you "delete" the information from the flash drive, it does not permanently delete it until the "Trash" is emptied.
May 20, 2011 | Memorex Mini TravelDrive - USB flash drive...
Hi. my flash drive light comes on as i put it in. it stays on momentarily but after three seconds or so th ligh goes off. it doen't even show up on my computer
Flashing light means your flashdrive is being read. Try it on another computer, if it still can not be detected then it is broken.
Hope this helped! =)
May 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to rcover from my sandisk back to my library
1. Does the flash drive LED light up when you plug it into various computers? ( not just your own fortesting purposes).
2. Does it pop up in windows explorer at all? ( Should be labeled as Removable Disk by default)
Your flashdrive may have essentially died. Test this flashdrive on multiple computers to determine whether its your computer or the flash drive. If you are trying to recover information try out the app Recuva which can be found on google search. Your information may have been corrupted.
May 05, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do I download pictures from my computer onto a usb-16gbtr, there are no instructions with the flash drive
Just plug the Flashdrive into the USB port of any Computer and the Operating system ie: Windows should just pick it up with Auto play after a few seconds. Open the FLashdrive under My Computer?Computer(depends on the version on windows you are using) Open the Mass Storage device or the drive that shows the Flashdrives details and then just copy your pictures from the folder which you saved them and then Paste them into the Flash drive.
If you want a more detailed description, just let me know what Windows or Operating sytem is on your Computer or the device you want to download from and also the make and model of the Flashdrive.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Jan 31, 2011 | Computers & Internet
How to install Memorex USB 2.0 1GB flash drive on computer with microsoft 2000 OS
windows 2000 should recognize the flash drive immediately after it is inserted. The flash drive should install itself. Besides, there are only drivers available on the Memorex website for Windows 98se.
Jul 26, 2008 | Computers & Internet
How do you install and use a USB Flashdrive
just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
Feb 25, 2008 | Electronics - Others
Memorex black cd-r discs
these disc have a compatbility issue with a lot of computers and players reading from the dark recording surface .
the solution is simple use memorex cdr that have a mirror type recording surface on back the more reflective the recording surface the easier the media is to read stay away from dark recording surfaces.
Jan 10, 2008 | Memorex Black CD-R Storage Media
Open Questions:
Computers & Internet Logo
David Payne
David Payne
