Question about Proscan 40LD45Q TV
TV does not power up...outlet is good. What could be wrong?
  • 70 Answers
I believe the power supply has failed. You may inpect the power supply for swollen or dried out capacitors, also check your fuse.
hope this helps
Posted on Aug 27, 2010
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Purchase new 32'' tv 2-day ago, will not work in a GFI plug outlet trips GFI each time you reset, is there something wrong with unit? works fine in a non GFI outlet
Good News!!! GFI outlets are made to trip when a large amount of power is pulled through them. A GFI is basically a small circuit breaker.Your television set is probably just pulling more amperage than the GFI is rated to handle. That means the GFI is working properly And so is the TV!
May 05, 2011 | Televison & Video
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
Tv won't turn on
Try plugging something else (a lamp?) into the power-outlet, to see if the wall-outlet is providing power.
Try plugging the TV into some other "known-good" wall-outlet.
Take the TV to a repair shop, and have them trouble-shoot.
Nov 09, 2009 | Soyo Televison & Video
Tv shut off, and wont turn on. It flashes when you press the power button. NO clue at what is wrong.
is the tv on a power strip? unplug the tv from the power strip or wall outlet wait one minute then plug back into the wall outlet and not a power strip. TV should power back on.
Oct 12, 2009 | Sabre LCT371BKA LCD TV
Tv wont turn back on
Either of those, so check both.
Jul 04, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
No power light on TV, power at outlet, acts like internal blown fuse
Make sure your main switch near the power cord where fits in the tv is on,if it is and you have power in the outlet you have a power supply problem.i sugest to take it to a repair shop.I am a technician but i am in Puerto Rico otherwise i would be more than happy to fix it for you.I have a good experience with these tv and have fix a lot with thesame problem.
Regards and good luck,
Jorge.
May 10, 2008 | Protron PLTV-3750 Television
No power Polaroid 3232 LCD HDTV
Power supply must be something wrong. You may need to bring it in a service center near you.
Sep 23, 2007 | Polaroid FLM-3232 Television
Proscan 40LD45Q TV Logo
23 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
