Question about Online Computers & Internet
I have a 40gb old hdd. it was a currapted .i install the hdd in other pc then i boot from bios setup. but hdd is not booting. the error is display -the disk is not bootable... how i boot the harddisk now. ple give some steps to follow.
    President:
  • 2,678 Answers
If the drive is corrupt in one PC it will still be corrupt in another.
There are apps for recovery and attempted repair of HDD's but you have to weigh off the cost of the apps against cost of neww HDD.
Posted on Aug 27, 2010
How to change the boot order in bios
press f1 to access the bios setup menu.
then choose boot up menu to change the option.
Dec 10, 2013 | IBM Netvista Intel Pentium 4 2.4GHz /...
How to Enter Bios for MSI A6400 Laptop?
Press Del while the Press DEL to enter SETUP message displays on screen after powering on the computer. SETUP, in this case, is the BIOS.
Jul 27, 2013 | Computers & Internet
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I tried to change a bad? 40GB hdd with an 80GB one, all on an Acer Aspire 1680 PC. I put Windows XP Prof SP2, on the 80GBs hdd, and after a few days work , at boot time, I saw the next error...
Check to see if the BIOS can see the HDD. If it can, check to see if the hdd is damaged(80GB is an old hdd so it could have been mishandled).
To Enter the BIOS, you can press the F2 key when the computer boots up.
To check the HDD, use the diagnostic tools on UBCD.
UBCD is free and it will require a blank CD. Follow the intructions on the download page if you do not know how to burn an ISO. Also, you may need to press a certain key to boot from CDs or make sure the BIOS boot order is set correctly.
Good luck.
Mar 25, 2011 | Computers & Internet
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Dell Lattude D800 HDD change - doesn't boot
I suppose it can support upto 100GB , just get the BIOS updated to the latest release and check in the setup if the disk is accepted .
Dec 16, 2008 | Dell Latitude D800 Notebook
Missing operating system
missing operating system message usually means that your HDD is pooched, or corrupted
check your bios settings to check that it can still "see your HDD"
if you can hear your hard drive going "click, click, click" when attempting to boot, that is usually a bad sign
to perform setup use orignal recovery setup disk or OS disks of your choice (BOOT from CD) to install OS from scratch.
Sep 30, 2008 | Microsoft Windows XP Professional With...
HDD not reconigized
You need to press F2 or Del on start up and enter the bios to get your hard drive recognised, normally F10 to auto identify or select automatic. You will have to select the advanced cmos settings and set your cdrom as first boot device and insert your XP cd save settings and exit, as the system wont boot because of the hardware change, so you will need to let it install the setup files, then use the option to press R to repair the system or enter to install windows again.
Sep 11, 2007 | Abit SG-80 Motherboard
Can't start up the laptop as Media test failure
You may have to go back into the bios and see if there is an option to automatically find HDD, or you may have to manually enter them in the Standard Bios Settings. It may be that the old HDD are still in the bios's recognised setup.
Dec 13, 2006 | BenQ Joybook 5100U Notebook
Computers & Internet Logo
50 people viewed this question
Top Online Computers & Internet Experts
Don A
Don A
Anthony Kelly
Anthony Kelly
Level 1 Expert
Mohammed Jamal
Mohammed Jamal
Are you an Online Computer and Internet Expert? Answer questions, earn points and help others
