Question about Dell UltraSharp 2407WFP 24" LCD Monitor
I have 4 year old dell 24 inchultrasharp monitor and the screen goes a deep pink every now and then and it clears by itself any ideas i have checked drivers and screwed it tight
  • 11,361 Answers
Please follow Louie advice and if you are going to DIY repair then you should look at my albums of failed monitors to get some ideas what you are in for.
http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 27, 2010
Testimonial: "thanks it looks very complicated so no try"
  • 732 Answers
Rsood, You must disconnect--reconnect the VGA plug from the video card/pc vga jack a few times (3-4). If your "pink" screen "hue" continues to show-up, then someone will need to investigate the internal "switch-mode-power-supply/electronic-ballast circuit (inverter) of your "cold-cathode-fluorescent-lamp" back-lit lcd monitor. Could be bad capacitors on power supply board and/or poor intermittant (thermal-cycle-caused) soldering of the electronic components on the printed circuit board. Read and follow links you find in the fixya profiles of: "budmrtn" "buddymc" "12fixlouie" and visit YOUTUBE. Make notes!! Tell me if vga connector stuff works or not? 12fixlouie
Testimonial: "looks good to me"
4 Suggested Answers
  • 3 Answers
SOURCE: Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Posted on Jan 11, 2008
ErusTownsend
  • 592 Answers
SOURCE: I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Posted on Jun 03, 2010
  • 66 Answers
SOURCE: Dell monitor S199WFP....the blue power light stays
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Posted on Jun 18, 2010
Pink Screen
Probably the color temperature setting or some other color settings - since you didn't specify your monitor's brand and model, it's hard to guess.
Anyway, most monitors have a "Reset to factory defaults" feature - you may want to make use of this...
Mar 10, 2010 | Dell Computers & Internet
This D1025TM, horizontal distortion from active-off state
If it it part of a Win98 system that makes it well past its best, some20 years old.
Time for a new one.
Jun 24, 2017 | Dell 17" Monitor
Dell Inspiron 6000 about 3 years old. When I boot up, sometimes it goes through the early Windows XP screens and then goes to a blank screen. It indicates that activity is going on but cannot see it on the...
The screen cable is most likely damaged. Try connecting an external monitor. If it works, you need to take the computer to a repair center to have the cable changed.
Aug 24, 2009 | Dell Computers & Internet
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
One monitor clear the other not good fonts
I installed a better video card that supported dual monitors without splitting the signal.
Nov 19, 2008 | Advueu Technology ADV178T 17" Flat Panel...
1 year old dell monitor
Dell monitors separate 3 year warranty. call tech support at 800-8228965. have the monitor replaced.
hope this helps.
thanks.
Jan 09, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
80 people viewed this question
Alun Cox
