Question about Northland 36ARWGP 36" Built-In All-Refrigerator with White Aluminum Interior, 8 Glass Split-Shelves,...
I have a Northland Designer Series 36in. all refrigerator, white interior. It is making a noise like there is a bent fan blade somewhere. It is coming from the area around the tempreture dial in the ceiling. Who can I call to have it repaired? I live in Ft. Myers, FL
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my northland refrigerator is not making ice
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 25, 2010
  • 500 Answers
SOURCE: Repair tech says the compressor
Hi dshine605,
No you don't. Unless no power is measured at the compressor coming from the module (PCB), then yes, you have to. If there is power getting to it, but the compressor does not start, it is simply a normal Compressor replacement job. This includes a Compressor, Charging (shredding) Valve, Gas, and in some cases a Pencil drier.
These repairs are quite expensive, but if there is no internal leak, then it is worth it.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 16, 2011
I need a phone number for customer service for Northland Designer Series Refrigerator
This is from a manual
NORTHLAND KITCHEN APPLIANCE DIVISION Northland Corporation Greenville, Michigan 48838-0400 P.O. Box 400
And then we go to Yellow pages
Northland Corporation Write a Review Add a Photo .st0{fill:#FFFFFF;stroke:#E2E2E2;stroke-width:2;}.st1{fill:#ECECEC;stroke:#E2E2E2;stroke-width:2;}.st2{fill:none;stroke:#E2E2E2;}.st3{fill:#FFFFFF;stroke:#E2E2E2;}.st4{fill:#ECECEC;stroke:#E2E2E2;}
Be the first to review! 1260 E Van Deinse St, Greenville, MI 48838
(616) 754-5601
Northland Corporation in Greenville MI
Nov 29, 2016 | Northland Refrigerators
Why is it making a loud clicking noise?
If it makes a loud clicking noise on startup or shutdown, it could be caused by a weakness in the springs that hold the compressor in place in the hermetically sealed shell.
If it is a constant noise while compressor is running it could be a slightly bent fan blade hitting its surroundings. Check the condenser and evaporator fans.
Aug 31, 2015 | Refrigerators
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Samsung RS263tdbp fan making noise when closed and opened refrigerator doors
is there a build up of ice around it or is the fan blade bent and hitting something, otherwise u may have a bad motor in the fan going out
Jul 17, 2014 | Samsung RS263TDBP Side by Side...
I've just installed a Northland 36" refrigerator and 36" freezer. The compressors seem to be noisier than the sub zeros that I have previously installed. Is there any way through adding sound insulation...
If you feel the unit is much louder than it should be, have the dealer check it. It could be one of the refrigeration lines rubbing something. This will cause noise, and potentially cause a failure. They should check it free of charge to protect their investment in not having a warranty problem in the future. (Tell them this) Otherwise, trying to add any kind of insulation etc, can disrupt the factory's design airflow and VOID your warranty.
Jan 05, 2018 | Northland 36" Built In All Freezer - 36AF...
Loud fan noise
The fan in many of these units is very close to other things and the blades will bend and hit causing a terrible noise...either the fan has to be remounted or the fan blades bent to make sure they will not hit...
Then you will have peace and quiet...
heatman101
Apr 22, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Door doesn't close tightly. How to adjust cams to close door?
loosen up the hinges, align door and tape it in place. Tighten hinges, remove tape and your good to go.
Mar 31, 2010 | Northland 24" Built In All Refrigerator -...
Noise from fridge when doors are closed.
There is a good chance this is the culprit.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Good Luck! Buddy777
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Northland 36ARWGP 36" Built-In All-Refrigerator with White Aluminum Interior, 8 Glass Split-Shelves,... Logo
73 people viewed this question
Top Northland Refrigerators Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Bill Boyd
Terry Weaver
Terry Weaver
Are you a Northland Refrigerator Expert? Answer questions, earn points and help others
