Question about Brother LS-2125 Mechanical Sewing Machine
Need help catching the bobbin...not able to stitch
I have a LS-2125. I followed instructions on threading both the needle and the bobbin. Last night I was able to start my garment and successful stitch one piece. After that I have not been able to sew anything. When I've tried, I can not get the thread to catch the bobbin. I have threaded and re-threaded everything. I've have cleaned out the bobbin section numerous times. Any help would be GREATLY appreciated.
  • priceless_j May 06, 2008
    Is this a timing issue because it won't pick up the bottom thread? I'm so lost. I'm a beginner and don't want to get discouraged.
  • starxox Dec 01, 2008
    I have a Kenmore sewing machine. Model no. 385-16231300
    Does not pick up bobbin thread
    Problem Solver:
  • 6 Answers
Go back and check to see if the needle is inserted properly. I have had this problem on other machines and have found that this is a cure for some. i just got in a hurry and put it in wrong(most times the flat side of the needle goes towards the back).
Posted on May 06, 2008
My brother LS-2125 will not do zigzag stitch needle moves from side to side but only does occasionally zigzag
If you are saying the needle zig-zags but the upper thread is not catching the bobbin thread every stitch, then it could be a timing issue.
Jul 08, 2016 | Brother Sewing Machines
Bobbin shuttle
1. Clean shuttle with your sewing machine brush to remove old broken threads, lint, and sweep out the feed dogs carefully. 2. Rethread making sure you have the handwheel turned toward you, all the way up. 3. Lift presser foot up BEFORE you put thread front to back in eye needle. 4. Set machine on straight stitch sewing. Attach straight stitch foot if necessary. 5. Make sure 5-6 inches of thread are pulled toward you from threaded needle. 6. Pull up bobbin thread. 7. Pull 5-6 inches of bobbin thread and put it, along with needle thread under presser foot. 8. Put fabric scrap under presser presser foot and LOWER it now. Make sure, too, that the needle is correct size for fabric you're sewing. 9. Do a test. You may need to set tension at 4, stitch length at about 4 and width at 6. Just test it and adjust tension in very, very short turns. Another tip: Put one drop of good quality sewing machine oil on the hook, lower left-hand side. Make sure when you thread bobbin in the bobbin case to hold bobbin between thumb and forefinger and pull out about 4 inches of thread after you make sure thread unwinds top left (if you are right-handed!). Guide the thread into the slot in edge of bobbin case (screw sits on top of this "edge". Pull thread under tension spring and then into the delivery eye. Never panic, my friend! Try this and see if this helps. You should probably insert new needle too--just in case "old" one bent. Jimmy
Mar 31, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Top thread wont catch bobbin thread
Is your needle in backwards? check that the flat shank is to the back. Also ensure it is fully up into the housing.
Is the top thread actually threaded through the needle okay?
Obviously if you are an experienced user of this machine and have rechecked your threading up fully and the needle, then it is possible that the timing is out, ie needle at the lowest point as the rotary hook passes behind it to catch the needle thread - these two things moving together must be in expactly right sequence to form a stitch.
If you suspect that this is what's happening, then probably time to drive it to the service shop.
Sep 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a brother LS-2125 and the thread from the bobbin is not catching and is not being pulled through.PLEASE HELP! i need it for an assignment! :)
Here are some things that may fix the problem:
1. First, replace the needle
2. Next, remove the thread and completely rethread the machine
3. Remove the bobbin, clean any lint or thread from around the bobbin, and replace it.
Try sewing again on scrap fabric.
I hope this helps.
Apr 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
The machine is threaded correctly, bobbin in correctly but it won't pick up the bobbin thread. The needle is not bent. It just suddenly started this. Please help!
Firstly please check that the needle is in the right way, flat shank to the back, and is fitted all the way up into the needle holder. This will affect stitch formation as the scarf at the back of the needle is where the rotary hook moves to catch the thread from the bobbin to form the stitches. A new needle never hurts either, should put in a new one for every new sewing project as they last only 4-6 sewing hours before they start to go blunt.
If this isn't the problem, then perhaps the timing is out, have you stitched into something, a pin or the sewing foot by accident to knock the timing out?
If so, time for a trip to the mechanic.
Mar 08, 2011 | Brother LS-2125 Mechanical Sewing Machine
Presser foot will not feed and the thread wont catch
The presser foot is not suppose to feed. It's purpose is to hold the fabric in place as the feed dogs feed the fabric from the front to the back of the machine as stitches are formed.
Check the needle to be sure it is installed with the flat side of the needle shank facing the back of the sewing machine.
Refer to your manual to be sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the guides.
Pull the bobbin thread up by lowering the threaded needed down and then back up. Pull both threads under the presser foot and to the back of the machine.
Set the stitch length to 2.
Place a scrap of fabric under the presser foot. Holding onto the ends of both threads, lower the needle into the fabric for the first stitch.
If the machine still does not stitch, the machine may need to go in for maintenance as the timing may need to be adjusted.
If the feed dogs are not moving, this also needs to be repaired by sewing machine service tech.
Mar 29, 2010 | Brother LS-2125 Mechanical Sewing Machine
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
161 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
