Question about RCA HD50THW263 50" HDTV
WHERE CAN YOU GET PARTS FOR THIS TV . I NEED INPUT BOARD
    Sergeant:
  • 252 Answers
<a rel='nofollow' href="http://www.tvrepairworld">www.tvrepairworld</a>
Posted on Aug 27, 2010
No back-light,No picture, but has sounds. How can I fix it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 03, 2015 | Vizio E500i-B1 50-Inch 1080p Smart LED...
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
Hi I have a dmtech lv22xtm TV I have picture but no sound any suggestions?
Sound comes from the Main board. That's the one with all the input cable connections go.
TV Parts Universal TV Stands DLP Chips ShopJimmy You can get all the parts you need here.
Jun 05, 2015 | Televison & Video
Screen black
Here's the test to determine which board is faulty. With the TV on, as usual, shine a flashlight on the screen to see if there is a faint picture. If there is, then the ballast board for the backlights is bad. If there is no visible picture, then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 13, 2017 | Hitachi P50H401 50 in. Plasma HDTV
Curtis LCD2425A will not turn on
Good day!!!!
TV won't power ON..
This is the common problem..
Power supply board or main board..
Please try this procedure to determine the faulty parts.
  1. Open the back cover.
  2. Check the input of the power supply board it should have 220vac or 110vac depends on your voltage comes from the outlet.
  3. If you don't have voltage input of PSU..Please or try to replace the power cord.
  4. If you have voltage input on PSU..Please check the output voltage of it..It should have 5vdc for the main board,12 or sometime 16vdc for the audio and 24vdc for the inverter board(back-light).
  5. If you encounter voltage drop on the output..Please check the power supply board if have leak/bulged on the top capacitors..Please replace it with the same type,ratings and value.
  6. If the 3 voltages mention above are normal..Your main board is defective you need to replace it because main board is not for D.I.Y repair due to the surface mount type parts on it..
I hope this solution will be helpful..
Thanks for using fixya...
Sep 12, 2011 | Televison & Video
My Sharp LCD panel color TV. does not have any power supply. When I turn on the power button, its power indicator led from red to green for split second and completely turn off without any life. What...
Good day!
This are the steps to find and fix that problem.
  1. Open the cover of your TV.
  2. Disconnect the input supply of system board or main board that comes from the power supply unit.
  3. Power ON the TV to check the voltage reading of disconnected connector to the input of system board by using voltmeter.
  4. Check the 5vdc and 12vdc by using voltmeter.If you got voltage reading of 5vdc and 12vdc,try to connect the input connector of the system board and check the voltage again.If no voltage when you connect it.There's a shorted parts on your system board.Replace the whole system board because its very difficult and expensive to repair it.
  5. When the input voltage of system board doesn't have 5vdc and 12vdc even disconnected on the board.The problem is on power supply.
Check the following:
  • Fuse-Check the fuse if busted.
  • Transistor and diode-Check the transistor and diode if shorted.
  • Resistor-Check the resistor if open/change value.
  • Capacitor-Check the capacitor if leak/bulge on top.
If you found the defective parts that mention above.Replace it with the same type and ratings.
NOTE:If the following parts are OK and the problem is still there.The power supply have major problem and its not for D.I.Y..
Thank you and good luck
Apr 25, 2011 | Sharp AQUOS LC-32D43U 32 in. LCD...
TV has a mind of it's own. I turn it off & it turns itself back on. It pulls up the input menu without me hitting the input button. Then it switches between the input options without me hitting...
U have some skills like take things aparts and putting it back together again?Yes?The tv Tuner signal board have problems,might even be the CPU itself have some kind of shorts.The Tuner signal board,that the board,where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Oct 28, 2010 | LG 47LG50 47 in. LCD HDTV
Panasonic model CT27G14A need front A/V input board. Where kids plug in video games. Have resoldered but only works half.
U out luck,but can tries Ebay.com or Shopjimmy.com for salvage parts,CRT tube tv impossible or near impossible to find parts if it not a DLP tv 40" and up.
Jan 11, 2010 | Televison & Video
My 27" truflat RCA tv, which is 4 yrs old, went blank
Hi,you will need a soldering iron and a voltage needle so you can test the Ic components on the main board. you will need to test the transistors as well. once you find the bad parts, you will have to order them and remove the bad parts and replace them with the ordered parts by using the iron and solder. this issue will be located on the input side of the main board. you should notice it by the discolorations on the board. (truama poitns)
Mar 13, 2009 | RCA TruFlat 27F520T 27" TV
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
Feb 18, 2009 | ViewSonic N3251w 32 in. LCD HDTV
RCA HD50THW263 50" HDTV Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
