Question about Amana Washing Machines
Have an Amana Model #LW8203W2 that starts leaking water when about 8 gallons of water are in the tub. Can you tell us what might be wrong? Thanks, Nancy
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
aborcass
  • 2651 Answers
SOURCE: Washer wont work.
does it sound like it doing something??trying to agitate?? can you spin out the water??. if not id look to possible bad lid switch, open adn close the lid a few times, can you herea distinct "clicking" sound just prior to the lid closing??? if not you nave a bad lid switch. acesses by removing the front cover panels, and removing screws holding down main lid, lid then tips back giving you acesss to the switch itself
Posted on Apr 27, 2008
  • 177 Answers
SOURCE: amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
Posted on May 13, 2008
SOURCE: water in leaking into tub overnight
One of the solenoids in part #8181694 is not closing completely. This part is easy to replace.
1. Turn off the water from both inlets and unplug the machine.
2. Unscrew the hot/cold from the machine. You may want to use a bucket to collect the 2 cups of water that will pour out of the hoses.
3. From the rear of the machine, use a #20 torx head to remove the 5 bolts holding the top cover.
4. Slide the cover back and lift to remove.
5. See the attached picture. The red arrow in the upper left corner points to the inlet valve.
6. Note the color of the electric connections. The white plugs are on the right. The black on the left. Unplug these.
7. From the rear of the machine, remove the #20 torx bolt which holds the valve in place.
8. Using pliers, pinch the hose clamp and pull the rubber hose from the inlet valve.
9. Lift out the inlet valve.
10. OPTIONAL : Connect the valve to a garden hose using a female/female hose bib. See the attached picture. Turn the part upsidedown and shake it. This will loosen the solenoid and some water will squirt out. Turn it rightside up and see if the valve seals itself. Repeat if necessary. Repeat on the other inlet. In the picture you can see the leak coming from the valve.
Posted on Aug 01, 2008
Amana dlw330ra, loud and leaking
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 11, 2008 | Amana DLW330RA Top Load Washer
My washer has leak more and more over the last few months. Model # LW8203W2. What do you think the problem may be? any help appreciated.
Hello there:
If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 20, 2010 | Kitchen Ranges
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Feb 28, 2009 | Amana LW8203
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Amana washer
T
May 12, 2008 | Washing Machines
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
