Question about Gateway FPD2275W LCD Monitor
Compaq colour 21ich monitor trinitronfbt
When i on the set 4frication second FBT SARTS and gets off thier is neon lamp which glows 4second kindly help out
  • premtron May 12, 2008
    i got u r suggestion let me try
    Guru:
  • 859 Answers
It is going into power saving mode. Can you disable power saving mode?
Posted on May 11, 2008
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Dear sir as im facing a problem in my sansui pj42multiplex that the fbt has got spark and the tv gone into standby....but after replacing the fbt the set dosent goes to power on mode...kindly help me
That sounds like the uProcessor has been damaged by the static discharge when the fbt arced out. Unfortunately this sort of added fault is common.
Check there is oscillator at the uProcessor. If there is then the fault is possibly elsewhere and the next stage is the line oscillator control board signals.
Mar 02, 2011 | Televison & Video
Rear tail light won't light up
You might have a bad wire. If it was both tail lights, could be your tail lamp fuse or brake switch.
Feb 05, 2011 | 1998 Lincoln Mark VIII
How does the internal light work
Since your question is not very informative on a specific problem, I can only answer as to how a light works in general. In Power supplies, there can be 3 different types of lamps used. These are used as indicators to signify an "on" condition. Type 1 is Neon and upon analysis typically has 2 rods running parallel to each other. A Neon lamp will fire at about 60 volts. These re usually constructed with a dropping resistor that will limit the current and thus drop the voltage from about 120v AC to the required voltage for operation. The second is Incandescent. These lamps have a filament which glows when power is applied. They are available in all shapes and sizes and can operate from about 3 volts up to 120 volts, ac or dc. The third is the LED (light emitting diode) These last the longest of all the indicators and are the most efficient as well as lease expensive. They are available in almost any color and will operate with as little as 1-1/2 volts dc.
Nov 06, 2010 | Electronics - Others
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
Lamp cover error please help
lamp/cover problem in sony es 4 is in two parts, in first case, the led keeps blinking.in this case problem is related with cover switches and thier connection with main board. in second case, led glows permanently, in this case either lamp or ballast pack may be faulty.
Feb 08, 2010 | Sony Office Equipment & Supplies
I have an unlockes lg neon and is nto wanting to get signsal from my tmobile sim card ;;; before i had three months working perfectly fine.
most companies dont support unlocked devices but you will need to contact tmobile for thier network settings to be reconfigured into the phone
Jan 15, 2010 | LG Neon GT365 Cell Phone
How do you replace the flyback on aRCA D52W20 52 in. Rear Projection
All is needed is to de-solder the bad FBT and solder the new one.
But I would not recommend anyone with no TV repair experience to this kind of work. We are talking about the most dangerous area in the TV set, and subject is the Flyback Transformer it generates thousands of volts that can kill in a matter of a second. The CRT (is connected to the FBT) can store High voltages for days even when the TV is unplugged. My friend, I don't like to see people get hurt so, don't do it.
N Sabre
Nov 08, 2009 | RCA Televison & Video
Compaq colour monitor 21" MODEL P1100
TRY THIS, open Monitor , look inside the PC BOARD for a burn solder or cold solder around the area where you see a transformer , re solder any suspicious solder and try again, hope this helps , please rate this solution , AJ
May 06, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
