Question about Mitsubishi VS-5043 50" Rear Projection Television
57" DLP Mitsubishi
Tv turns itself off by saying " Check airflow to see if blocked" It has at least 10" on each side and still does it if i move it to open room. The orange light comes on after it turns itself off which means room is to warm (according to manual) that is false also. Any suggestions. i tried cleanig the fan in back and using a house fan to keep air circulating,...no luck...please help
  • 2 more comments
  • marty noltie May 06, 2008
    thanks dan, its a wd-57732 or just a wd-y57 i'm not sure which one.
  • Anonymous Sep 19, 2008
    My TV is Model # WD-Y57 on screen has display TV will shut down in few seconds due to air flow.
  • Anonymous Jan 20, 2009
    It is shutting off saying check air flow when I unplug it for awhile it will work for a while Can it be a bad bulb? getting tired of a new tv broken after 2 years any suggestions? rjhassler@comcast.net
  • Anonymous May 01, 2009
    I have the exact same problem, it says to check the air flow but there is nothing blocking it. Sometimes it can go without doing this for a couple of days to a month and then it starts up with it again
  • 4,234 Answers
It is possible that either the heat sensor or the protection circuitry has a problem. The protection circuits will always err on the side of caution. If the fan is good, I'd be looking for the sensor. Can you update this with the model number please? I can check for more details once I have that info.
Thanks,
Dan
Posted on May 06, 2008
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My tv turns blue and turns itself off
optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Jul 12, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
Mitsubishi 56 inch dlp,screen says tv will turn off in a few seonds,air flow seems to be blocked,tv turns off and orange light comes on???? Have to push reset button to clear orange light,this is constant...
Hello!! It might be either that the tv is overheating because of the lack of air, or it may also be your ballast.
First of all I recommend you clean the fans, so the air flow won't be blocked, don't use something that mioght damage some of the boards that are inside, you can buy one of those air cans to clean computers, if that does not work, I recommend you listen closely and notice if there's a clicking sound, if so it might be the ballast.
Mar 14, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi slim DLP, keep or sell? can't decide
That problem with the "AIRFLOW Blocked" is now covered by Mitsubishi (parts & labor) Contact a good repair shop and they should fix it free. I had that same problem the tech came out and fixed it in about 30min.
May 19, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Jul 30, 2007 | Mitsubishi WD-57732 Projection Television
Televison & Video Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
