Question about Garmin GPS
I hooked up my GPS to the usb still frozen still will not go back to normal.
  • 1 more comment
  • rich_brandle Aug 28, 2010
    Still having no luck with my GPS , try downing program to update but its not working
    Hi i downloaded the Garmin updater plugged in the GPS now its saying can't find device
  • rich_brandle Sep 02, 2010
    Hi i did up load the updater hooked the GPS to the usb cable so what it's doing now it shows Gps hooked up to a computor and there is a white line below it show a wee bit of blue and that were it stops.
  • 2,973 Answers
Please remove the battery for a minute or two. And then reinsert it and power on the device.
Posted on Sep 08, 2010
You will need to update the Garmin software to fix the freezing issue, click on the link below to download and install the webupdater
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Posted on Aug 27, 2010
Frozen reset
Turn it off & take out the batteries - after 2 min, try putting the batteries back in & switch it back on.....
Jun 29, 2014 | GPS
My GPS C330 got frozen and it does not want to turn off or on how can i fix it
reset it when it freezes in ON mode. if it comes back to normal then next thing u should do is get on to garmin.com and install any available update.
Jul 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen is frozen, can be turned on and off but wont go passed initial stage
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
Get frozen old the time my gps garmin 660
if its frozen to the point that it will not turn off, lift the external antenna and push the reset button, then start it up again and see if its ok. if not
make sure its has a good charge,plug it in to the usb port2.gif on your computer for a few hours.
if that fails, try a reset
note: the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
hook up the nuvi to the web updater and get the latest update
you can get the Web Updater HERE
bill
Nov 06, 2009 | Garmin Nuvi 660 GPS Receiver
Maestro 3250 will not boot past magellan screen.
When I talked with Magellan tech support they told me the GPS would not be recognized until the unit was sent in to be repaired. The screen was frozen on the start up screen. When asked how much it would cost, they said they had a customer loyalty program and would sell me a new GPS or a refurbished one if I sent in my old one. They could not just repair mine. The cost was more than a new unit on e-bay. No more Magellan products for me.
Aug 09, 2009 | Magellan Maestro 3250 GPS
I have a nuvi 660 that just comes up woth black screen
hey i have nuvie same problems plus keyboard fubby numbers all i did was plug usb into it and computer done virus check on nuvi folder in my computer unplugged it brand new back to normal hope helps
Jun 15, 2009 | Garmin Nuvi 660 GPS Receiver
The computer won't recognize the gps
When I hooked the nuvi 350 to the PC, the PC like a normal USB device. It could not recognize the drive on the nuvi. The solution is to change the drive letter as outlined in the manual. Google nuvi 350 manual (I got it at http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf) , download the manual, and go to the appendix. Look under 'USB interface troubleshooting'. This worked like a charm
Apr 18, 2009 | GPS
Frozen screen
I have had a frozen screen on my TOM TOM - I solved this problem by resetting the TOM TOM. I did this by pressing the pinhole reset buttom on the back of the unit - labled RESET.
Nov 27, 2008 | Tomtom ONE GPS Receiver
Frozen
Hook the Tomtom using the USB cable to your computer4.gif. You should see the Tomtom drive under My Computer as a drive letter.
Backup1.gif all data1.gif from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Jan 04, 2008 | Tomtom GO 910 GPS Receiver
FROZEN SCREEN
By David707,
Since posting ma last re: Screen Freezing on external charge; I did manage to get the system back to some normality by pressing the Reset button located underneath the GPS Antenna flap. However this is likely to delete personally stored data on the system.
I should also state that the same problem occurs when I connect the 610 t my PC via the USB connection (another way to externally charge the battery).
A more satisfactory answer required though.
David707
Dec 28, 2007 | Garmin nuvi 260W GPS Receiver
GPS Logo
128 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
