My tx-28pl10 6 years old & picture does not come on for about 3/4 minutes when switched on ,only sound . Is this a common problem & are panasonic willing to repair as a good will guester. regards
  • 4,234 Answers
Yes it can be repaired. No Panasonic won't repair it for free as it is well beyond the warranty period. This is a normal wear and tear type of problem and is easily fixed. There should not be any parts required, most likely just a bunch of poor connections resoldered.
Dan
Posted on May 06, 2008
TV stopped working, how can I fix the problem below?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sep 12, 2014 | Panasonic VIERA TX-L32X5B 32" LED TV...
My picture tube tv is eight years old & now I get a good pcture fore only 20 minutes 'till it goes black
I would suspect one of two general things---one if the picture dims out and does not just cut out bad solder connections for the filament in the neck of the tube---a look there with set on will when bad reveal if this is the case.
Bad solder connections somewhere on the main board--this happens with age as the board expands and contracts from heat and then cooling down.
If not a do it yourself person it may not be worth a shop repair on a 8 year old set------
Let me know if need advice.
Nov 05, 2012 | RCA Televison & Video
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
When powered on with remote,makes usual sound,green light comes on,then goes off,blinks 3 times,goes off and contiuesly blinks until unplugged. Problem is picture suddenly went black with no sound.Could it...
my samsung tv model number is sp50L7hx it's 6 years old, when I turn it on it's a not really nice picture just nice sound, after 2 hours the picture is off just sound .... after I was switch off TV and switch on again ... the picture is very bad and just for a ten-twenty minutes ... what's is the problem? I'm never change the lump ... or is it a some problem with T-Con decoders board or is it a lump?
Jun 19, 2011 | Televison & Video
When I first turn on the receiver in the morning to watch TV, (ATT Uverse), I get an error, "No Signal." After about 10 minutes, if I switch the input on my TV, then go back to the correct input, it...
if you are using hdmi cable, you should switch to using component cables for the video - (red/blue/green) - you will need to use the white/red for your sound (or the optical cable) - uverse is aware of the issue and if you call they probably wont be able to send someone out but they can give you a credit for buying the cables
Aug 30, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Panasonic colour tv TX-29P150X (Made in Malysia)
sounds like you have a intermittant thermal condition and this could be the regulator IC the video jungle/sweep Ic. Anything in the switching poewer supply or sweep curcuit. This is a hard one unless your there with a meter and a schematic to measure voltages when the set goes out then you can use a can of freez sprasy to lightly spray on the supected part. Sorry i cant be of more help. Good Luck
May 17, 2006 | Panasonic TX-32PM1 32" TV
Televison & Video Logo
Top Televison & Video Experts
