Question about Kohler Home
I have a mira combiforce 415 biv and it is leaking from the cold water supply side from the body of the unit could this be a problem with the body of an internal issue
  • 127 Answers
SOURCE: WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: hi got a mira 415 shower with a leak from the
yes! service kits are available..local plumbing centers should have them in stock
Posted on Sep 25, 2009
  • 122 Answers
SOURCE: low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Posted on Jan 30, 2010
bloues
  • 56 Answers
SOURCE: I have a Mira Sport shower 12 mounths old. Water
if the water is leaking out the head, unscrew the head and put thread tape on arm of shower were the male thread is and make it tight again, if the arm ... unscrew the arm and put thread tape on the male thread of the arm and screw into feamale thred that is an the wall. if not 1 of those are the problem , clarifi and all give u a solusion
Posted on Jul 08, 2010
packrat1948
  • 528 Answers
SOURCE: mira 415 how to set temperature after fitting new
You should not have to. Replacing the cartridge should not affect the temp setting.
Posted on Feb 09, 2011
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
What is idling relearn procedure fo dihatsue mira 2008 car?
Idle Air Control System needs adjusting. The throttle body has the butterfly in the wrong position.
Take it to a specialist!
Jun 21, 2017 | Cars & Trucks
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
Using alot of water but engin does not seem hot 2009 dihatsu mira
You could possibly have a cracked cylinder head and the water is being forced through this crack ending up as a fine spray in the cylinder/s. The head gasket may also be faulty.
Pouring cold water into a hot engine can cause this, the engine must be running when hot and when cold water is added.
Oct 22, 2014 | Cars & Trucks
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
2007 sonata water leaking under throttel body
under the throttle body is the cold start unit where two hose pipes are and the one works as an inlet with first start with cold and after with hot water feeding and the other as out hot water return to engine. The job of that unit is to get the water temperature and as electronic connected with the ecu is giving the message for cold start rev up until the water temperature change to hot and revs dropped to the correct according to ecu. most propably is either one of the two hoses leaking or the flange itself.
Sep 09, 2012 | 2007 Hyundai Sonata 3.3
Hot side is cold cold side is hot
hello, this can happen if the shower body unit was installed incorrectly, the installer connected the hot to the cold side and cold to the hot side, what you can do might be a bit difficult but the water supply lines are reversed you need to open up the wall and attach the cold and hot lines to the right sides.. hope this helps
Jun 04, 2010 | Moen Monticello Collection 1 handle Shower...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Home Logo
71 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
