Error reported when trying to print - Office Equipment & Supplies
  • 3,037 Answers
Can you please explain the error and provide the make and model of the printer in question
thanks
Posted on May 06, 2008
  • 2,334 Answers
What is the brand and error you are getting?
  • Jaime Hernandez May 06, 2008
    Hello albertbroes, I think you made a mistake when you rated the solution.
    In this case, you should let fixya knows to correct it.
    We still need to know the brand and model number of your printer as well what errors you are seeing when trying to print.
  • 13,433 Answers
Hello
Which error?
do you have the drivers installed?
Wont print server reports
hello,
to print a server report you should be the admin if you are please check if you are in the whight mask to print the report
Sep 12, 2012 | Casio QT 6000 Point of Sale Terminal
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
Oct 20, 2011 | Sharp Office Equipment & Supplies
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
Trying to set up fax to print when sending fax
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Wont stop printing TX report!
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgHere are some of the instructions you'll need, but you can also find more assistance by accessing the online Canon support site and searching the exact error message you get. (click here)
ssue:
ERROR LCD: INCORRECT PAPERSIZE
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Here are instructions for changing the setting of the tx report:
Issue: How do I change the TX report
Solution: Changing the TX Report-IC D/PC 1000 Series
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif > to select [FAX SETTINGS], then press <Set>.
  3. Use <la.gif > or <ra.gif > to select [REPORT SETTINGS], then press <Set> twice.
  4. Use <la.gif > or <ra.gif > to select the option you want.
Name Description TX REPORT 111OUTPUT NO
111PRINT ERROR ONLY
111REPORT WITH TX IMAGE
111111ON
111111OFF
111OUTPUT YES
Enables/disables automatic printing of a transmission report. No report is printed.
Prints a report only when a transmission error occurs.
If you select PRINT ERROR ONLY or OUTPUT YES, enables/disables printing of the first page of the fax under the report.
Prints a first page only when a transmission error occurs.
The first page is not printed.
Prints a report every time you send a document.
(The factory default setting is in bold face.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
k24674
jasbo
jasbo
