Question about Pioneer PRO-200 60" Rear Projection Television
Pioneer pro 99
Red standby light on will not power up
  • Pioneer Master
  • 8,617 Answers
Thats usually a problem in the standby voltages not being correct. If you would like to diagnose this with help from a support tech you can get the service manual emailed to you after purchase at the following link and they provide free tech support to help you diagnose and repair the set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 06, 2008
Why does my pioneer elite pro-ro6u have a red light that says standby instead of blue light which is on??
proubly just the design my kenwood has a red light for standby and goes out when turnd on
Sep 07, 2014 | Pioneer Audio Players & Recorders
Pioneer plasma pro 930hd tv no power
if the power board looks good my guess it is the main ic that is broken
Nov 22, 2017 | Pioneer PRO-930HD 43 in. Plasma Television
When turning on the TV all I get is a click sound, the red light remains red and no picture or sound.
Sounds like the tv is on standby, and needs to be switched on after via the remote control.
Oct 11, 2012 | Pioneer PRO-99 TV
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Aug 21, 2008 | Pioneer PRO-99 TV
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer Elite Pro-99 Power Problem
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 19, 2006 | Pioneer PRO-99 TV
Pioneer PRO-200 60" Rear Projection Television Logo
55 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
