Question about Samsung SyncMaster 940N 19 inch LCD Monitor
My sync master 940n Powers on for a moment and displays a crisp clean image ... then nothing but black. I have tried disconnecting the VGA cable to see if the self test works but it only works for a moment also, The power button glows a constant blue. I have seen other similar problems on this site but there seems to be some ambiguity as to whether the Sub board, Picture Board or Power Supply is to blame. Which is the offending component ? And where can i source one ? Many Thanks in advance J
  • 11,361 Answers
Look for bad caps first on the boards per Louie suggestion.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Service maunals:
http://elektrotanya.com/?q=showresult&megnev=SAMSUNG&megnev2=940&kategoria=&kat2=schematics
Posted on Aug 27, 2010
  • 732 Answers
Jgddy09, If you find out how to "part" the front "bezel" from the "rear cover" by watching some video clips at YOUTUBE, then you may want to visually inspect the "switch-mode-power-supply/ccf-lamp inverter board for BAD (failed) dc electrolytic filter capacitors that may or may not have the brand name of "CapXon" printed on them. Plenty of pictures on the web of this BIG PROBLEM!!! Let me lmistyrel over on aim. com or 12fixlouie on fixya know what you see on the printed circuit board. Also do some reading in my and "budmrtn" and "buddymc" fixya profiles. All that you need do is type nickname in the "search for sol.... "bar on the fixya screen and click "search. Then you can read to your heart's content to discover solutions to the BLACK screen of Death and then decide the fate of your monitor. Have you done the Flashlight-test?? I always look at the power supply(SMPS) board first!! Tell us what you find inside. good luck. 12fixlouie
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Sync master monitor gives message smart image on and smart image off
This actually shows that there is a problem with the VGA port on the computers motherboard. If the monitor shows the smart image on and off, it means its okay but it is not receiving the signal from the computers VGA port. This could be a result of broken or bent pins on the VGA cable from the monitor, or there is a problem on the VGA port on the computer's motherboard. Usually in cases like these, we have to be careful and be exact as far as problem identification is concerned. So i would suggest the following steps for you to follow
1. Check for broken or bent pins on the VGA cable (the cable from the monitor to the computer), if all is well
2. Try a different cable, just to confirm (probably a new one)
3. Try to connect the monitor to another computer and see if it responds
4. Try to connect the computer to a working monitor.
These 4 steps will help you to identify which part is the problem. And since this looks like a hardware problem you might have to replace the faulty part with a new one
Mar 22, 2012 | Computers & Internet
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Black screen, won't boot up, fan kicks on for a few seconds only, then powers down
check the display on the external monitor through the vga port, if the display is fine , then its the problem of your laptop screen, some time this is due to the cable that gives display to the screen, take it to the technician and checks there
how do you like the solution rate it please
Oct 17, 2008 | Toshiba Satellite M35X-S109 Notebook
Samsung Syncmaster 940n - white screen
This is a known symptom of a failed power supply board. Here is a repair guide for this unit that shows how to dis-assemble the unit and then what to look for and replace to rebuilt the power supply board and bring the monitor back to life.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board.
I hope this helps you, if so please rate my solution.
BuddyMc
Mar 25, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Samsung SyncMaster 940N 19 inch LCD Monitor Logo
321 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
