Question about Motorola Mobility H700 Wireless Headset
Willnot pair w/ phone
I have a palm treo 700p, have used this headset before but the pass key will not link w/ my phone anymore. I have tried "0000", "1234", 00000000, and 12345678. What else can I try and is there any way to NOT have to use a pass key?
  • Anonymous May 15, 2008
    Lost instructions for my H700 Bluetooth. Looking to pair to my Palm Treo.
  • Anonymous May 20, 2008
    did anyone figure out what the pass code is????
Yes the exact problem except my phone is the blackberry curve
Posted on May 12, 2008
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
Pairing plantronics w. treo
Here is a link to the plantronics online pairing guide and here is the link to download the m2500 user guide. Good luck!
Dec 12, 2007 | Palm Treo 650 Handheld
It's paired up with treo, but when treo rings, the headset will not work.
there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
I recomend a Plantronics brand headset with your phone.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Bluetooth connetion with Verizon Treo 700P
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne (www.palm.com) so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Aug 18, 2007 | Garmin Nuvi 660 GPS Receiver
Motorola Mobility H700 Wireless Headset Logo
63 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
