Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
When I start a load for the most part the cycle will not complete and continues to beeep refering to check load "LD" and flashes....
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Heard a beeping warning half way through cycle. Went in and Ld was message flashing. Tried to stop and restart, then machine started making buzzing noise. Cannot get machine to do anythind but lock lid...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 16, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have the whirlpool Cabrio model WTW6600SB2. We keep getting the code LD when we use the normal rinse cycle. Also trying to do a clean with bleach cycle and t is supposed to go 60 mins and goes less...
The LD:
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Service Manual
More Here
Feb 03, 2011 | Washing Machines
Hi I have a Maytag model fav6800aww stopped in mid wash cycle,now if you try any cycle it makes a whirling noise for a few seconds then goes to the light flashing pause mode.Thanks.
No erro codes to the console correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
