Question about Mitsubishi WD-62531 Projection Television
Have a wd-62531 picture was dark, changed bulb picture is still very dark. is there anything else i can try, thanks joe diprima
  • 734 Answers
Try to change brightness control in menu setup?
Posted on Aug 27, 2010
Mitsu wd 62531 colors are rather dark. Any solutions
check you brightness level , if that does not fix it it sounds as if you may need to replace the bulb, you can get just the bulb or bulb in housing, if you are the least bit handy save the money and just buy the bulb, be sure not to touch the front of the bulb as oils on your skin can damage the new bulb or at the least shorten its life, this is easy to do just fallow the directions in your manual
Jun 15, 2011 | Mitsubishi WD-62531 Projection Television
Picture is dark
the problem is that the lopt is loosing power this can be due to a leak. in it there fore you will hear a hissing sound or the lopt is simply past its time. and will need to be replaced ( the lopt is a unit that sends power to the screen or in this case the globes the less the power the duller the picture)
good luck hope this helps
Jul 12, 2010 | Mitsubishi WD-62531 Projection Television
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
The picture of my 51" Mitsubishi TV WD 62531 is dull or yellowish.How can I fix this?
It seems the problem you refered is quite complicated if you are not qualified technican. It needs full servicing of main board, including all the heated areas on board.You will need a soldering iron, and a multimeter to test the components, such as resistors on CRT socket board. The yellowish colour is caused by dry joints, (a common fault causing components to shake from its soldered base by heat). Resolder the main board and test the resistors on the CRT socket board for defective ones, change it. If you think you are qualified for this, give it a try or else consult a technican. thanks
May 15, 2010 | Mitsubishi WD-62531 Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Tv has picture but it is dark with settings set to brightest settings
First thing to do id replace the lamp. If that doesn't help then the light engine needs replaced.
Dec 09, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
