Question about Samsung Digimax S500 Digital Camera
My pictures are 'blue' in colour. What can I do to correct this please
    Brigadier General:
  • 11,967 Answers
Set your white balance to "auto WB"
Posted on Aug 27, 2010
Testimonial: "Many thanks indeed for this! "
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Blue picture
Be sure if you are using the 3 wire video (component input) that the green blue and red wires are connected correctly on DVD player and tv. If these are switched around or all three are not connected correctly you will get an off color picture. Do not confuse SINGLE WIRE (yellow composite video) with the 3 wire coponent or progressive scan inputs .
Aug 29, 2009 | Televison & Video
COLOURS PRINTED DO NOT MATCH SCREEN COLOURS OF ITEMS
I would try cleaning off the nozles on your print cartridges. If that doesn't help, replace them altogether.
May 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Samsung Digimax S500 Digital Camera Logo
26 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
