Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
I was wiping the inside top of the fridge when suddenly the operating sound stopped. I must have touched something. How do I get it going again please?
  • Bosch Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Top draw on our dishwasher isnt working .bottoms fine.wont start just beeps and the numbers /display is jumbled
If this has stopped working suddenly then most likely the controller on the top drawer has packed up. Before panicking, take a clean moist kitchen wipe and clean the edges inside around the drawer including the touch buttons inside. Sometimes the grime confuses the controller. Best of luck.
Oct 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Freezer suddenly defrosted!
sounds like you may have one that's in the recall..search maytag recall refrigerator and see if yours is one of them.free repair.
Jun 12, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Top mount fridge stopped refrigerating, maybe compressor?
It could be a bad compressor or the Start Relay that is bad, an easy way tell if the compressor is bad or not. If the compressor is hot to the touch it's probably the Start relay is bad, but with the Fridgeidare they have had some compressor issues. Good luck
Apr 25, 2009 | Refrigerators
Top sections of Freezer and Fridge not Cold at all
hi!!! You seem to have a problem with your evaporator fan motor or the defrost mechanism on the frig.That the defrost timer..Listen manually turn of your refrigerature and turn it on again when all the ice melts away if the fan work or runs then its your defrost timer on the frig.Easy fix man..Good luck..
Jan 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
After cleaning MER6775AAB, upper oven has stopped working
See if the top heating element is open. Also check the switch that feeds power to the element.
Aug 28, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool Arc7410 fridge/freezer
that isn't a good model number doesn't show up on sears but if you're saying you touch the cold control and it runs then the control has to be replaced,when it stops try tapping on the control and see if it starts,the control tells it when to come on and off,they do go bad.go here and look up your model and you can see the part number,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and you should see a tag with the model number,if the freezer is on the bottom or side by side open the fridge door and look up at the right hand wall near ceiling and the tag is usually there,also there's a timer in some of these units and the timer tells it when to go into defrost and if this sticks this can also happen and they can be in the same area up in the console where the light is or like my fridge both are up top on fridge side,if you know where the timer is you can try turning it with a strait screw driver and see if it starts when you turn the timer but try to do this gently,if you tap the cover and it's the cold control you might start it lol all it sometimes takes is a light tap and the control will work again,if it doesn't start when the timer clicks from turning it just a few clicks then it will be the cold control and most probably it will be that,you can change it out,not hard,just install it the same way you take it out.
Dec 02, 2017 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
