Question about Sony Ericsson Cell Phones
No sound in ringer - Sony Ericsson Cell Phones
    President:
  • 1,118 Answers
First You Go to Phone setting in Sound & Ringing Setting and check the Phone Ringing Setting if Ringing Setting alrdy OK
But No Ringing So
Secnd Option:
Your phone Ringer Default SO Please change Ringer
and Ringing Sound Problem will Solved
Posted on Aug 27, 2010
Ringer does not sound
  • Make sure the ringer is not muted or the volume is down.
  • Make sure that the sound file associated with the ringer exists.
Do you get any sound when you make a phone call to somebody?Do you get sound if you plug in amplified speaker?
Mar 13, 2015 | Cell Phones
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
S5570 mic speeker ringer not work
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Jan 16, 2013 | Samsung Galaxy GT-S5570
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
The sound quality is very bad
Hi, are you talking about the ringer or the ear piece sound.
Ringer: if the ringer sound bad it means that the ringer is damaged and will need to be replaced.
Ear piece: When you make calls and you people hardly you, It means that the earpiece which allows you to hear
people that is located at the top of the phone if faulty and needs to be replaced with another one.
Take care.
Aug 31, 2010 | Cell Phones
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
Jun 08, 2009 | Vtech T2326 Cordless Phone
Ringer problem
it may be due to some small loose connection. remove the connections once and re fix them again.
May 31, 2009 | Nokia Cell Phones
Sound problem
good evening ! the problem of your phone is buzzer and speaker ,or the audio driver ic try to chagne that ! good luck !..god bless....
Sep 06, 2008 | Nokia 6600
Cell Phones Logo
128 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
