Question about Lands Phones
I need help with BUSH telephone SN100-3 all 3 handsets read SEARCHING and I need to use phone?
Http://www.alcomonline.com/user_manual/alcom_cordless/SN-100.pdf
Manual for this phone
Posted on Mar 06, 2011
Why does my bush orb cordless phone keep saying "searching" .?.
Either your base station is not plugged in, or is malfunctioning.
"Searching" means the handset is "looking" for a wireless connection to the phone's base station.
Jul 10, 2014 | Lands Phones
Is serching and not working
second handset keeps searching and has no dile tone
Nov 29, 2013 | Emerson DECT 6.0 Expandable Cordless Phone...
Phone reads searching after being disconected and reconected
If this telephone is part of a multiphone set there is one base that is connected to a phone line (or if Magic Jack the internet cord). The other phone charging seats work by radio signal from the base unit. Place the phone on the base unit and let it reconnect for a few minutes. If you bought this expansion set without already owning a base unit, you will need to get the base unit or take this expansion set back for a unit that will opperate by itself.
Jan 17, 2013 | Uniden DECT 6.0 Cordless Telephone...
I have a Bush Atmos telephone and answer machine. It's only about 2 years old, however the handset seems to have lost contact with the base as I can no longer get a dialling tone and cannot answer...
first thing you need to check is the battery as it seems like you have lost charge and it is not recharging and you can order these batterys on line not to exspensive so just undo the back cover and you should see the battery and if you have another handset then take the battery out of that to see if the handset is working fine before ordering a battery
Jul 06, 2011 | Cell Phones
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Handset reads "searching"
The reason the handset says "Searching" is because it can not find its Base Station. What handset works with a notebook? I had not heard of such a thing.
Sep 15, 2009 | Philips VOIP3211S/05 IP Wireless Phone
Hi My phone battery died and I recharged it. Now it is not recognizing the base and keeps searching.
Press and hold the end key, then while holding the end key, press and hold the # key. After 3 or 4 seconds the handset will beep and ask if you want to deregister the handset, select "Base unavailible" and confirm. Then the handset should read "Handset not registered". Place it on the base charging cradle and it should register.
Jul 08, 2009 | Uniden DECT 6.0 Cordless Telephone...
Handset display reads "searching". No dial tone. No response.
I am sure you have solved this problem by now. For others who might face the same problem...just unplug the batterry of the handset and plug it in..wow it works!!:))
Jan 20, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Lands Phones Logo
211 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
