Question about Bose Cinemate Digital Home Theater System Speaker
Try to get bose remote to control sky hd boxs need code and set up instructions thanks
To programme a Bose Cinemate remote control for Sky+ & Sky HD
  1. Press and hold the Setup button until all 5 green lights show
  2. Press SAT button
  3. Using number buttons, enter code 01175. The SAT button should blink.
  4. Press SAT again. You should now be able to control the Sky box.
Note: Use "Exit" for "Backup". Also there is no green button to access the planner on Sky+
Posted on Mar 11, 2011
I need a code for grundig 7 in 1 remote to operate sky plus (not hd) box. it is a Pace manufactured sky plus box.
0027,0048,0091,0063 are the codes to check with Sky Plus. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 24, 2013 | Grundig 7 In 1 Universal Remote Control -...
Bose av 18 media center remote codes
Codes to check with Bose AV systems are 1231 1298. If you wish to get more, check the sites linked here. http://electrohelponline.blogspot.com/
http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 15, 2013 | Televison & Video
I need a code for a bush bpdp 42 hd 2 tv for my sky hd box
2577 worked for me for the Bpdp 42 hd bush tv
Jan 07, 2012 | Televison & Video
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Sky HD Remote and BOSE 3-2-1
Usually products with remote control mostly by default always use the zero code. Try 3 or 4 zeroes
Jun 20, 2009 | Bose 35504 Remote Control
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
I need the code fro a new sky box hd
To find the codes for the sky boxes you will need to look at the user guide/manual that came with the remote control. Go to Sky's website for the remote codes. select version 8 for all new Sky + HD remotes
Mar 01, 2009 | One For All URC-3445 Remote Control
COde to let a Universal Jumbo Remote work with a sky+ HD Box
don't have a answer! i need a code for my jumbo control for my tv Samsung DYNA Flat
Dec 29, 2008 | Universal Remote Control Remote Control
Bose Cinemate Digital Home Theater System Speaker Logo
1,832 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
