Question about Samsung DVD-VR330 VCR and DVD Recorder
DVD copy to VCR no colour
The content of the DVD gets copied to a VHS tape, however, it comes out black and white - instead of in colour. HELP!
The unit is defective and needs repair/replacement
Posted on May 07, 2008
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
Diamond VC500 is not showing my video. I can hear the audio and if I click the refresh button I can see the video for a second and then it goes back black. Help, I am trying to convert my VHS tapes using...
This depends on your operating system and video display hardware, but a lot of the time, updating to the latest video driver for the card will solve the problem.
The other possibility is that you are set to the wrong video source (for example, the S-Video instead of the composite).
The third possibility is that you are set to be "PAL" capture for an NTSC source or vice versa. If you are in the US, set NTSC. If anywhere else, select PAL.
Sep 29, 2011 | Diamond Multimedia ( VC500) Video Capture
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
VCR has no color picture is clear but black and white
Vee, V, a Vee Cee Rrrrr ? Not a DVD?
If you are playing a VHS tape that should be color content and it's in Black and White ... well you could check the tracking control if there is one on that model. Otherwise it sounds pretty broken. Probably NWR. Not worth repair. Try Cleaning the heads with a cleaning tape???
Nov 22, 2009 | Memorex MVT2135 13 in. TV/VCR Combo
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I have a Samsung DVD-VR357. I get no color on vhs tapes. I only get black and white.Picture is good. DVD color is ok. When I copy VHS to DVD, the DVD copy is in black and white also. DVD copies from...
Are you trying to copy a comercial VHS tape to DVD?
If you are then macrovision copy protection system on either the tape or in the machine is the reason for the loss of colour.
There's not a lot you can do about it. If you want to copy commercial material you will need to transfer it to a computer and get a program to do it. But unless it's unavailable it is cheaper to buy the DVD version I have found and you will get better picture and sound too!
If it does it with a none comercial tape (ie something recorded of the TV). Then it could be a head fault or something else. In which case try cleaning all the heads guides etc first.
Jun 20, 2009 | Samsung DVD-VR357
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Everything's in black & white
are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Aug 14, 2007 | Mitsubishi HS-U778 VHS VCR
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Jun 25, 2007 | Emerson EWD2202 DVD Player/VCR
Samsung DVD-VR330 VCR and DVD Recorder Logo
Jerry Greenberg
Jerry Greenberg
