Question about Maytag Neptune Washer
How do I clean the mold from front door gasket?
  • Maytag Master
  • 43,501 Answers
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<BR>Here is a tip about how to clean your washer<BR><BR>How to have a Clean Washer<BR><A rel='nofollow' href="http://www.fixya.com/support/r4356970-clean_washer" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r4356970-clean_washer</FONT></A><BR><BR>heatman101 <BR style="mso-special-character: line-break" clear=all><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><o:p><FONT size=3 face="Times New Roman">&nbsp;</FONT></o:p></P>
Posted on Aug 27, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 27, 2010
    How to have a Clean Washer http://www.fixya.com/support/r4356970-cl...
    heatman101
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
Mold in front door gasket
TRY LETTING VINIGAR SET ON IT OVERNIGHT
Apr 13, 2014 | Frigidaire Washing Machines
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    How do I clean the front door gasket area?
    Here is a tip that I wrote about that problem...it tells you how to clean your washer and also how to prevent it from coming back...
    I will also include a tip I wrote on washer maintenance...
    http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
    http://www.fixya.com/support/r4312694-washing_machine_maintenance
    heatman101
    Asker's Testimonial " heatman 101 Just wanted to say thanks for helping me with the mold
    Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
    I want to clean can i run thru with vinger,bleach and what else can i do?
    With the machine off, open the door and spray Clorox Clean-Up inside of the front rubber door seal/gasket. You should be able to gently flex the rubber seal to get inside of its cavity. This is where mold, etc. tends to accumulate. After a minute or so, brush or wipe away any debris that has accumulated. Be careful not to wear good clothes! Once you have completed the gasket/seal cleaning, begin a hot water cycle with no detergent to thoroughly rinse the bleach from the door seal/gasket.
    From then on, occassionally glance inside the gasket/seal to see whether there is a build-up of mold, etc. and repeat the aforementioned process.
    Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Mold on the gasket of kenmore duet front loader. have run the clean cycle, and scrubbed the gasket and inner liner also
    This is a common problem with front loading washers. To prevent this issue leave the washer door slightly ajar after use. It will promote air circulation and prevent mold.
    Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Mold on gasket; front lint trap clogged; washer reeks
    run an all hot water cycle using hilex bleach should kill the smell and mold
    May 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold on gasket
    The mold is common with the front loaders all you can do about the mold is wipe out the water that is in the gasket after a wash and leave the door open. DO NOT TRY TO CLEAN WITH BLEACH. The bleach will make the gasket weak and cause it to rip and then cause a leak.
    Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    22 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
