I need a manual for a NuArc FT40V3UP flip top plate burner.
Cant find the model number for a maytag gemini double oven with ceramic cooktop. Any advise?
On the Maytag Gemini Series Double Electric Oven, the Model and Serial number is located on a flip-up metal plate/tag which is located on the upper left side/rear of the of the control panel. There is no need to move the stove away from the wall. Simply place your fingers over the top left edge of the control panel and flip the metal plate/tag up from a point just left of the control panel's center and flip it to the left (it's hinged on a screw to the far left of the flip-up plate/tag).
Dec 30, 2012 | Kitchen Ranges
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
The large two size burner is not working correctly. The large size will come on but the small inner burner will not
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jun 24, 2010 | GE Profile JB968 Electric Kitchen Range
One of my large burner not working
Sep 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Need to know the BTUs on stovetop Burners
BTU ratings are usually the Model Number plate which is located in one of three places for Maytag:
1-Underneath burner top if top lifts up easily
2-On left lower front edge of frame with door open
3-Left edge of front oven frame with drawer open
Aug 23, 2009 | Kitchen Ranges
Front big burner not working
Jul 10, 2009 | GE Profile JSP47 Electric Single Oven
Large section of dual burner not working
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
I have a GE profile Glass top M#JSP47COF4CC That is cracked but can't figure out haw to remove. Have already removed 4 screws under control panel still won't budge
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
Mar 27, 2009 | Kitchen Ranges
Front right burner on GE glass top range not working
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
GE Elec Range - front left burner will not turn on
Dec 26, 2008 | GE Profile JB968SHSS Electric Kitchen...
249 people viewed this question
k24674
