Question about AEG Washing Machines
Our AEG Electrolux Lavamat washing machine isn't working. It was working perfectly yesterday apart from nit using the conditioner from the conditioner dispenser. When it was switched on today the power is getting to the machine and tghe information panel is working however when any program is chosen it goes straight from washing to draining without any washing. I'd appreciate your advice/suggestions. Thanks Bill Wallace
  • AEG Master
  • 19,396 Answers
Re:"when any program is chosen it goes straight from washing to draining"
That usually means that either there is a filling problem, or that the pressure switch must be replaced.
If water pressure from house is less than one bar or more than ten bars, it will go straight to drain.
Disconnect and connect back power by disconnecting power cord or tripping the circuit breaker.
Move the appliance and cehck the inlet hose at the back, ensure that it is not kinked or blocked.
This machine may also have a flow meter attached tio inlet valve hose,Check if there is a flow meter and filter attached to the hose before valve, in case remove it using plyers and replace the filter.
If that does not fix the problem, then internal parts must be tested.
Testing will start from inlet valve, to check pressure switch and finally the timer board.
Posted on Aug 27, 2010
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
I received an error EH1 in my AEG electrolux Lavamat L64850l washing machine, how can solve it?
Problems with the electrical power supply, the appliance remains in the alarm state until achieve conditions of work, and stabilizes the voltage and frequency, and the machine resets quenching (controller to the position "0").
Obviously there is a problem in the electrical network so my suggestion is to call your local electrician or try connect power supply from any other room.
Dado
May 04, 2015 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a AEG AKO LAVAMAT 6100 DIGITRONIC washing machine. The soap & fabric conditioner doesnt dispense.Can you help me please?
AEG AKO LAVAMAT 6100 DIGITRONIC washing machine. The soap & fabric conditioner doesnt dispense This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 04, 2011 | Washing Machines
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72640 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
